avguytx
Lunatic Member
I have a few different console amps that have been sitting idle and I really need to get one rolling soon. If you guys had the choice and had these 2 amps, which one would you do first? Which one sounds better or is there a difference? Pros and cons? I have a Magnavox 9304-20 and an RCA RS-177 (R I think?) and one of them needs to get started on. I have some solid oak for making a wooden frame around it, I just ordered Banana style jacks for the speaker terminals, a fuse holder, a rocker switch for power and some nicer board mount RCA's. I know there are caps (and resistors?) that need to be replaced which is no problem. What about the diodes? I'm a tube newbie so I wanted to ask the pros so be gentle!
I would imagine that both had some sort of equalization circuits in them that will need to be removed so, I know I'll be asking for help on that. I will be using a Carver preamp for the most part with either of these amplifiers. Attached are a couple of pictures of each amp and if I need to snap a couple of others, just let me know. I am really excited to be able to listen to some of the older speakers I have on some tube power...especially my Electrovoice Interface C's! Both amps were fully working when removed, also. The RCA seems to be heavier in the transformer department. Does that make a big difference in the two?
Yeah, I know. I still need to clean up the RCA amp. I hope it turns out as well as the Maggie did.
Thanks for any and all help!
Here's a couple of pics of the Magnavox amp
And a couple of the RCA amp
