Relamping a 2235B
Jim Eck
Chicks dig the Mule
Begin by mixing one large beverage of choice, my choice today is a very large 7 and 7.
Unplugging the unit, never work inside of a unit with the power hooked up.
Remove the 2 philips screws on each side of the unit. Carefully remove the cover.
Place all small parts in a dish or something so you will not drop them or somehow lose them.
There are two philips screws that hold the meter lamps in place and 2 philips screws that hold the dial and indicator lamps in place. You do not need to remove them, loosen them enough to be able to slide the housings back gently to gain access to the lamps.
The fuse lamps are 8v 200ma lamps, if one is bad it is advisable to replace them all. The indicator lamps are 8v 40ma pin type lamps that will require soldering to install them.
They will solder in from behind.
The meter lamps are also 8v 200 ma and should also be replaced with the dial lamps.
Replace the lamp holders after installing the new lamps, be sure to tighten the 4 screws.
I like to clean the inside of the face plate while I am doing this, dust and such does get behind the face plate and your unit will look much nicer if you take the time to clean this.
Remove the knobs and slide buton by firmly pulling them off. I usually soak these while I am removing the face plate. Remove the 4 5/16 bolts and soak these also.
Remove the brass retaining ring and the face plate is free to remove and clean. Be careful not to leave any streaks or lint while cleaning the face plate.
While in here there is marginal access to the pots and some switches, you can do some good here but there are better vantage points for switch and pot cleaning.
Carefully clean the inside of the dial area before reassembly.
Without smudging the glass reassemble the face plate in reverse of taking it apart.
Replace the cover, plug in the unit and check your handy work.
One other important thing is on the Stereo light Marantz insists that you use the 12v 40ma bi-pin lamps not any lesser values, there claim is that the lesser draws can damage the IC in the FM section Marantz makes this a big RED WARNING. The other function lamps can be either 6, 6.3v, or 8v 40ma bi-pins, they should be marked if not a service manual may be required.
AK member dgwojo is a great resource and source for your lamp requirements.
Jim
Jim,
That unit looks like brand new now, great job!!! Dave. :yes:
PS - Nice props, Deoxit,a mixed drink, etc.!!
Great photos! This should really help people out when they're thinking about changing lamps for the first time. Thanks a bundle!
Jim's step by step procedure, complete with great pictures, should probably be a sticky. It is soooo informative. There are many, many questions in this forum regarding lamp replacement.
Nice Job Jim!!!
I agree is should be a sticky and it would be good for more people to post more examples like this in fixing other parts.
Pat
Well done Jim !!!
Good exposures with your camera. What kind of camera did you use and what were the exposure settings?
Great storyline and pics. I kept expecting to find the part where the unit was still plugged in and that 7&7 conducts electricity very well .... :D
Nice Job Jim!!!
Agreed! :thmbsp:
Thank you all. The camera is a Minolta Z1, using the automatic settings, I am a terrible photographer so I let the camera do the settings, it knows better than I do.
Yep, refill.:D
Jim
Can anyone confirm that the 2225 uses the same lamps as the 2225B shown here?
My buddy has a 2225 that has a number of lamps out that he wants me to replace so he can give it to his son to take to college next month. This was the receiver HE used in college, so it's important to him that his son use the same one... I can understand that.:yes:
Anyway, he won't be getting it to me till after New Year's Day, but I'd like to order the lamps now so they'll be here. Just need to make sure there aren't any different lamps in the 2225.
Check with dgwojo, this is a 2235B not a 2225B.
Jim
Great guide, i'm having a problem with my receiver though.. The lamps are held secure by plastic that has grown brittle over the years and i've already broke one of the arms.. Any suggestions?
I believe that if you do a search this issue has been addressed in the past, I think it was member Avionic, if not maybe it was Echowars.
Jim
