Ok, folks, there's some confusion over the 901 EQ thing, here, yet everyone is correct. I installed many, many 901s in the 70s both in residences and in discos, too, and was a warranty repair shop for Bose gear, among others back then.
Here's the scoop:
* The original 901 Series I and IIs were an inefficient speaker due to the cabinet being sealed a la KLH and AR speakers. The equalizers for these 2 models were different in the boost and cut curves. This means that the 2 equalizers are sufficiently different for one to want to locate the proper one.
* The Series III 901 is a completely different animal as it was a ported design in an attempt to overcome the large investment in amplification and grow the installed base of 901s. IMHO, it worked. The equalizer for this model was, again, completely different in cosmetics as well as in the boost/cut curves.
* The Series IV/V/VI series were pretty much tweeks on the same basic design of the IIIs. Although the equalizers changed in cosmetics and switch placement, the boost/cut curves changed very little, IIRC. These were mainly the result of changes in production of the drivers.
How many equalizers to use........
* One equalizer is a 2-channel device so you need only one equalizer when you're:
- Using a 2-channel power amp or receiver to drive one or two sets of 901s, assuming that you're paralleling the 2 sets of 901s
* Two equalizers will be required if 2 stereo power amps are used to drive 2 pairs of 901s.
- That is, one channel of the equalizer will be needed for the boost/cut for each of the 4 channels in this configuration.
On connection of the equalizer(s):
- The 901 equalizers were designed to be placed into the Tape Monitor loop of a receiver or integrated amp. You'll find a Tape Monitor on the equalizer itself to replace the one that was used up on the receiver.
- For a preamp/power amp configuration, the equalizer would be placed between the preamp and power amp that drives the 901s.
- Alternately, the equalizer _could_ be placed in the Tape Monitor loop of the preamp, just as with the receiver.
BTW, can you reproduce the same Bose boost/cut curves with a parametric equalizer? Possibly. I recall I once cascaded 2 SAE equalizers (one connected into the other to get as much as +/-24db of boost/cut) to try to get it to sound like the Bose EQ with a set of the then-new Series IIIs. It was difficult but costly to achieve. IMHO, its not worth the effort and expense. I can't believe I even had that much time to dink around back then.
Caution for any of the older Series I, II and III equalizers. These are getting to be 30 - 40 years old and will need to have some components replaced in order for them to remain reliable. I suspect there will be a deterioration in sound quality due to aging components, too.
Hope that helps.
Cheers,
David
