Mantis, I'm with you on ALL the confusion about the 6 million different versions of Deoxit.
Throw this out there for input...
I grabbed one of those 2 packs from the shack(contains 1-14g can of Deoxit-DN5(DN5MS-15) and 1-14g can of Deoxit Gold GN5(GN5MS-15)
The more I read the more I wonder if i picked up the correct stuff
So if i want to clean, say a volume knob(on the inside) or a speaker selector switch on an older receiver\amp, are these the correct ones?
The DN5 is just a cleaner though, correct? so no lube properties.Is the GN5(gold) designed to lube. I thought it was more of a, for lack of a better term, "contact enhancer" and acts as a bit of an anti-corrosive.(though it appears that it also offer a small cleaning action as well)
Sam Ash-yea, the Music Store sells some Deoxit products as well
They are DeOxit Cleaning Solution Spray(CD5) and CaiLube MCL Spray Lubricant(CMCL5SH6)
Would the CD5 work for cleaning POTS(Volume,Treble,Bass).
If cleaned with this would some type lube need to be used?
Just trying to get it "all" straight in my noodle before i wreck something
And at $15.00 for the shack 2 pack, there has got to be a less costly source...
Thanks
