Bauhausler
Rational Subjectivist
Hey, all. I've been fooling with a batch of AR speakers, trying to get a pair working with all live drivers. It looks like I'll have a pair of cabinets and woofers left over. I had a cab on my bench removing the tweet and mid, and I was thinking over what might fit in there to make a complete speaker out of it again. I love the bass of these ARs, but the mids and treble just aren't my absolute favirite. OTOH, the Kef B-110 is one of the best sounding drivers that I have on hand from about 200 hz to 3khz. Coincidentally, this driver has exactly the same external diameter and BCD as the AR mid. It will drop right in. Because the B-110 is open backed, I'd have to come up with some kind of more or less airtight housing to keep the woofer backwave away from the B-110's cone. Rough measurements indicate that I can adapt a metal coffee can, cut down to the right depth, as a housing for the back of the midrange. The housing would need some kind of stuffing as well, but fiberglass should work fine there. For a tweeter, the Kef T-27 can be adapted to fit the AR cabinet. The T-27 and B-110 are the classic combination used in several famous speakers, including the BBC LS3/5A, Fried H, JR 149 and others. I have two different crossovers built that would work for the B-110/T-27. In practice, I think I would mount 6 terminals on the back of the speaker cabinet for the connections to all 3 drivers. This would allow much better access for fooling with crossovers. Also, the speaker could be actively biamped, which might be necessary due to mismatched sensitivity between the woofer and other drivers.
Attached are pix with two views of the cabinet with the AR woofer, B-110 and T-27 placed in the baffle.
