Im looking for advice. I have a set of steel cage Advent Loudspeakers (i believe they are the A3).
i PM'ed KingBubba because i did a set of these not to long ago.
I thought his advice was pretty darn good so i thought i would post it publicly (hopefully he is ok with that).
"Refoaming is a great skill to learn and apparently Advents are a good woofer to start on. I did my first refoam by using shims because the seller had started a refoam and failed it and the dust caps were already off. It went well and the tension of the shims in the former allowed me to lift the cone high up in the frame to glue the underside of the cone for the foam.
First, download a free program called TrueRTA. It is a spectrum analyzer program that also has the advantage of having a tone generator. You want this because the easy way to refoam these woofers is not using a shim but instead feeding a tone into the speaker as the glue is drying. Use your computer to send the tone to an amp that will be used for your refoaming.
First step is to clean the cone and frame to the best of your ability. I used lacquer thinner or acetone to assist in this process. A Dremel tool is also a help for the frame.
Second step is to use a medium grit sandpaper to smooth out the surface of the frame and the cone. I use Aleenes Tacky Glue. I picked up a stiff bristle artists brush about 1/3" wide and cut the long handle down to make it easier to use. I rounded the handle with a file and sanded it down.
The third step is to attach a AA battery to the speaker with the positive to the negative. This will suck the cone into the frame, keeping it out of the way. Next apply the glue to the frame and then the backside of the foam. Let the glue dry for about two minutes. Don't use gobs of glue, just enough to cover well. After about two minutes apply the foam. I personally stay with the glue until it dries and use the back of the brush handle to press down the foam onto the frame as it dries. I like to use Aleene's because it dries slow and is forgiving to repairing errors. This makes refoaming slower. You will have to make your own choice about what glue to use. Reedger's glue is probably similar to Aleene's. When the glue is dry you can remove the battery.
Before you start step four, let the glue dry fully, at least an hour if not more. Next switch the battery so that positive is to positive and this will push the cone out which exposes the underside of the cone easier. Work the foam around the cone to get it under the cone. I then use the brush and carefully apply the glue to the foam and the cone at the same time. Once the glue is on all surfaces, I disconnect the battery and let the cone just fall onto the foam. In theory it should be centered when it does that. This is the time when I hook up the amp to the driver and apply a 30 - 40 hz tone at a very moderate level, audible but not loud. This tone will let you know if your cone is centered. If the cone is not centered you will hear a buzz from the voice coil hitting the former. This is when I appreciate the slowness of Aleene's glue. If you hear a buzz you will be able to adjust the cone one direction or another to get it centered. Once again I use the butt end of the brush and constantly keep up the pressure on the foam and cone to make sure the foam stays glued to the cone and doesn't slip off center.
Once the glue is set I will discontinue the tone and apply some regular music at a modest level and let it play for 15 minutes or so but never loud.
That is my routine. It is not the same as others but it works for me. Some people like a fast drying glue and I imagine the better you get at refoaming, the more reasonable that would be. Also if you were in the business of refoaming, you would not want to spend ten minutes on each drying cycle to fuss with the glue.
Good luck with your project."
Any other advice before i start the project?
Thoughts, Suggestions etc??
Thanks!
Thanks!
:yes:
