haggy38
Hi, I just wondering if any of you have tried this product?
S-721H cleaning fluid. Treat your equipment to the best on the market....this is the preferred choice of studios and professionals everywhere.A little goes a long way. It is formulated to clean audio & video tape heads, tape guides, capstans and pinch rollers. S-721H will remove tape oxides, tape adhesives, soils, oils, waxes, greases and other various contaminants while still maintaining the desirable properties of low toxicity. In addition, the evaporation rate is controlled to combine maximum cleaning power with fast drying. Due to S-721H’s low surface tension, excellent wetting of remote crevices is accomplished. Unlike alcohol, S-721H is non-hygroscopic, eliminating moisture or residue which can settle on components. This will promote extended life and healthy texture to the pinch roller.
These cleaning properties will improve the quality control of recording studios, broadcast stations, service facilities and general consumer use.
S-721H will enhance frequency response, improve tape tracking and shorten maintenance time. Safe to use on all new and vintage recording equipment.
Is all in one?
Regards,
Gustavo(pioneer rt 909)
Is all in one?
Regards,
