Windwalker
Anyone know of a quick change type connector?
I'm aware of
plugs, Lugs, spades, mini-pins and the like.
Here's what I'm after-Something along the lines of quick butt connector on the wire end and if you needed one of the above styles it would pop on to that.
Or maybe a Banana plug as the standard wire end and a mini-pin that would slip over the banana end and convert it
get tired of grabbing the wrong set of wires when testing different configs out
I'm aware of
plugs, Lugs, spades, mini-pins and the like.Here's what I'm after-Something along the lines of quick butt connector on the wire end and if you needed one of the above styles it would pop on to that.
