tensleep
Addicted Member
OK,
I've got my HK 330c, my DVM, my tech manual for the receiver and a clean work area. The lid is coming off!
Here is on the list to do:
I have the following questions:
Please make all the suggestions you like - I've got thick skin. Piccies will be coming as I progress.
- Clean the interior with compressed CO2
- Replace suspect wire ties (some have wire cores, can short out)
- Inspect for leaky capacitors
- Power on receiver
- Set bias
- What are the pros/cons to using a variac for initial powerup?
- The HK manual specifies a 50W 8 ohm resistor as a load between the speaker terminals. I have spoken to a local audio tech and he doesn't use a load resistor to set bias. Is this unique to this receiver and what method do you use?
- Is there something special about Deoxit, or will other products work, such as CRC Contact Cleaner?
- Should DC Offset be measured at the output terminals before and after bias is set?
