thesauce
Hey fellow vinyl heads, I have a question about aligning your cartridge. I have a overhang guage and bought a protractor from turntablebasics.com (the mirror one). My cart was originally aligned using the overhang guage for the Yamaha table I have. When I used the protractor to check the setup, it was way off (well, half way down the headshell). I had to move the cartridge all the way to the front of the headshell. This is a straight arm on a Yamaha P-750 and a Denon DL160. I'm wondering which one is correct? I'm assuming the protractor is... I think the higher frequencies may be slightly more detailed now, but it's hard to tell without a back to back comparison. Most importantly I want to make sure my needle is set up correctly so it doesn't wear badly.
Is this common for the overhang guage to be so far off? Also, it is normal for a cart to need to slide almost all the way to the end of the headshell to be in alignment?
I appreciate any advice.
Ben
Ben
