dividebytube
Well-Known Member
I recently picked up another Dynaco PAS preamplifier from E-Scam. I have owned three of these the past nineteen years, but always sold them for 'something better'. I planned to use this one with my McIntosh 250 solid-state amplifier that is used in my 'living room' system. The PAS still had three Dynaco labeled tubes that turned out to be smooth plate Telefunkens. The other 12AX7 turned out to be a Realistic 'Lifetime' tube that appears to be a U.S. made GE. The seller shipped it quickly and I got it within 2 days.
It's a fairly late unit and the faceplate is in very good condition too. I added an SDS power supply board which replaces the original filament suppy and the B+ can capacitor with modern components. I also bypassed the tone controls and loudness switch. Old Black Cat coupling capacitors are always suspicious, so I have an order of replacement Obbligatos coming my way. However I did replace two .02uf cap with some new Russian K40s .022s I had stashed away in my junkbox. I may be replacing the volume control, but right now it seems to track quite well. Shuguang 12AX7C9s are currently in place but I'll be rolling in the Tele's once I have everything else done.
Now it sounds very good driving the McIntosh 250 amplifier. Seems to have added some detail and fatten up the bottom a bit compared to running the cd player directly in. I'm always surprised how adding a preamp actually seems to help - perhaps the 'added distortion' helps the op-amp output of the CD player? Who knows - but at least now I can add a turntable. The 12AX7 with feedback is hardly an 'optimal' tube to be using, but it sure is musical. There is something very pleasing about these old designs.
I need to get a matching Dynaco tuner for it and I can have the total 'retro-audio' look. Throw in some better speakers than the vintage Wharfedale W60s and I'll have an excellent second system.
