Glenz75
Sansui and Pioneer Freak
Hi there, I thought I would share this fault symptom and cure with everyone as it was kind of an oddball fault, it may be a 'one off' but to anyone that is currently repairing one of these monsters it could be of some interest.:yes: Its a long story, so I'll try and make it as condensed as possible so here goes...
Powering the AU-20000 up from dead cold, DC would sometimes intermittently appear on the bases of the output transistors, from the drive stage and if you weren't lucky this would generally kill the output transistors!:gigglemad
But if a variac was used to slowly bring the power on from cold, a reduced DC supply voltage sat on the base and then it would clear and the normal +/- 0.5v would appear on the output bases and the protection would release as it should, and the amp would run fine.
I then was able to turn the amp off and on again as many times as I pleased without the variac and the fault would not reappear. It would only happen 'once' from cold!
A can of freeze was grabbed so I froze everything in that area, driver boards output stage area and no amount of freezing could duplicate the fault. I also checked every supply rail voltages etc,etc in both states cold and after being powered on and off a few times after the fault cleared, everything appeared to be in order.
So I did the usual, caps on the power supply board and driver stage, as they needed replacing anyway and checked/replaced all the transistors on the driver board of the suspect channel etc,etc and those of you who have worked on one of these, know that those driver boards are a pain to get out being modular and hard wired together!
But the fault still remained, and after blowing a set of outputs due to this prick of a fault I wasn't game to power it on directly without the variac until I had narrowed the problem down.:headscrat
I thought I had found the problem as I directly froze the temp sensing/bias transistor thats clamped on the output transistor heatsink and it started to play up so I replaced it and the fault vanished.....for about a month...then it came back and of course another set of outputs went west.....
It wasn't until one day I had the thing running, can't remember exactly what I was doing on it, and accidently knocked that circuit board sandwiched in between the heatsinks and there was an almighty 'crack' from the workshop speakers and it went into protection mode, I lunged at the power, shut it down immediately and checked the outputs - they where ok-phew! I gingerly turned it on again with reduced mains this time and flexed that board quite firmly and got the fault to reappear.....
The problem turned out to be dry solder joints on the through holes on the double sided circuit board in the output heastsink, I also checked the tracks for hairline cracks as well, they were fine. As a precautionary measure I did the other channel as well, just to be on the safe side!
And so the story ends!
After exhaustive testing and cringing everytime I turned the thing on from cold, (fully expecting it to blow up again!) I can the confidently say the AU20000 is fixed, and it has been running now for close to year and it hasn't missed a beat since and it peforms really well sound wise, I actually prefer it to the AU-9900...
Out of all the Sansui's and Pioneer's that I've serviced over the years, this one was definetly the most challenging one I've come across, solder fatique can do some funny things huh?
Thanks for taking the time to read this 'saga!
Cheers!
Glen
Cheers!
Glen
