Trower
Two-Headed Boy
Well hear is a project I have been working on for a little while. I got the original idea to make my own tonearm from this site http://www.altmann.haan.de/tonearm/. I looked further and found a couple threads over a DIYaudio.com about a unipivot based on Altmann's design and had to give it a wirl. The arm tube is just an arrow shaft, the headshell and arm base are from a Sansui TT that the arm tube had come unglued, the pivot point a ball point pen glued into the Sansui base, and the pivot point in the arm is just a set screw, the whole counter weight assembily is just made from random nuts and bolts and some wood, and the tonearm wires are Radioshack magnant wire. The arm is a bit rough, I am planning to build a nicer one now that I know it works well
The table is just some scrap plywood I found in the garage with the platter and motor from a belt drive Technics TT. I laminated it with some cork shelf liner because 1. it was cheap and easy 2. I thought it would help dampen the TT.
I just got it up and running tonight and wow does it sound good! I just cannot belive how much better it sounds than my Sansui Sr-535 I had before it. Dead quiet, very ballenced tone overall, and all this from a homade table and arm, with a 15$ cart!!
The whole project was very cheep, under 50 bux with a cartridge! Granted the cart is a 15$ AT
But it sounds amazing in this setup
some pics:thmbsp:
some pics:thmbsp:
