Well, I fell into a beautiful DIY 45 SET amp courtesy of Barrynsue. I want to thank him and Homer for making this acquisition possible.
Pix first....
Now for the admission of truth....:sigh:
I am keen to fire this bad boy up, but I don't know how long Barry has had it stored, so I am tempted to bake it, and will definitely variac it up. It didn't come with a schematic or manual, just the amp itself. So, I have a lot of questions.
1) I don't see an index pin or any marking on the underside of these 45 tubes. Howinthehell do you figger out which way to put them into the sockets?
2) Is it OK to variac them up like a PP amp? What tube(s) should I put in it before applying power? The rectifier for sure, but what else? Run it up to 90 VAC and then put the driver/power tubes in? Put the driver tube in earlier?
3) Hadn't heard of a 5692 tube before, but I guess it is a premium 6SN7. Red based RCA. Interchangeable with a 6SN7? Also has a 5V4 rectifier "Made in England", guess it's a Mullard. And the RCA 45's look identical, with a 035 date code. Can I safely assume this is a very nice set of tubes?
4) Can anyone tell anything about the circuit from the underside view? Looks like there are 2 chokes mounted underneath. Do all the caps look like new/non-leaky type manufacture? What can I assume about the other side of the PCB? Leave it alone until proven otherwise, or should I take it apart and check it out?
5) Anyone recognize the iron? Good stuff?
6) Do the 45's need to be matched? I have an extra pair a friend gave me earlier this week, but haven't even run them through my tester yet. However, they are different brands....:scratch2: How might I set the bias?
7) Anything else I'm forgetting? Anything I should make sure and do?...:scratch2:
TIA, as always......:thmbsp:
Pix first....
