I'm finally pretty much finished with this project.
If you were following THIS thread:
http://www.audiokarma.org/forums/showthread.php?t=209894
... then the name of the project makes perfect sense to you.
Based on a chassis from a very distressed Pilot 232 amp... which was stripped to the bare metal... the amp has very oversized transformers (power transformer specified for a large Motorola console, and output transformers specified for a Seeburg 24w/ch jukebox) and a circuit design loosely taken from the Stromberg-Carlson ASR-333 integrated amp.
Tubes are a 6CG7 (RCA cleartop) for the preamp stage, two 6GH8 driver/phase inverter tubes (Amperex), two pairs of 6BQ5 output tubes (RCA), and a GZ34 rectifier (Philips). Power is around 15w/ch... a STRONG 15w/ch., at that.
I've just started listening to it in earnest... after the first session, I made a few changes to the gain structure (added a bit more feedback to the amp section, reduced the anode resistor values on the preamp stage to drop gain and increase current, and added a 220K RF-stop/gain-drop resistor to the volume control, as well as going back to the original 100K grid resistors on the output stage, instead of the 220K resistors I had first experimented with), which helped to make the volume control more "usable" (originally, it was "wide-open" at around 11:00 on the volume... now it takes about 2:00 to get it near wide open on a standard line-input), and seemed to both smooth out the sound and increase the dynamic contrast a bit.
For a collection of parts from the "four winds", this thing really came together very well. The transformers run almost COLD, even though I'm running the 6BQ5s about as hard as is prudent (nearly 365V B+!). The nice thing about the amp, is that if someone wanted to "ease up" a bit, I determined that it will also work just fine with a 5U4 rectifier... which drops B+ to around 340V. With the cathode bias setup, it seems to run quite fine... no excess heat from the output tubes, even with the "hotter" GZ34 rectifier tube.
I'm gonna hook it up to some killer speakers, and listen for a while now...
Regards,
Gordon.
Regards,
Gordon.
