WilsonCreek
I came across this Yamaha NS-10 at the thrift and had to check it out. There was only one, unfortunately. I don't know if this was an early and dramatically different version of the later NS-10 or what, but it's not like the NS-10 monitor, that's for sure.
Dimensions on the cabinet are 20" tall, 14" wide, and 7" deep. I haven't decided yet whether to disassemble the thing to see what the woofer looks like from the front, but I am itching to. Can't see through the cloth on the front. The woofer seems to be about 14" tall and 10" wide, but it's hard to be sure. In addition, the magnet assembly seems offset from where the actual center of the cone is, although it's hard to be sure without removing it. The back of the woofer seems to be made of styrofoam, and it is very flat. The tweeter is bolted to what I suppose you would call the basket, which is essentially a big metal plate. It is a very odd woofer.
I found almost nothing on the web, although Yamaha NS-10 generates a lot of hits for the monitors. Did find one thing here though:
http://audio-heritage.jp/YAMAHA/speaker/ns-10.html
I can't read much, but a screen shot of the specs is the last attached image on this post. Looks like made in 1970, 40 -18,000 Hz, crossover at 5,000. Bass is pretty low and smooth, but the midrange isn't. To my ears it sounds muddy. But I was playing it last night with everyone asleep, and couldn't really test it too well.
Anyone have any experience with these?
