Philips AH797 receiver
Brian
An Old Geezer
As some my know I've ended up with a few Philips pieces at first more by accident than anything else and then by design. I currently have 3 of the following receivers 785, 796 and 797. Tne 797 was their TOTL of the series and is 60 watts rms into 8 ohms per side. My long time main system is McIntosh and for about 5 years have had a set pf Bozak Symphonys on them. More recently I've also pairs my Philips 6731, 572 and 578 tuner, preamp and amp with them and the set could easily be a main system.
During the past week I finally set everything aside to do some listening longer term with the 797 receiver on the Bozaks. Previously I had used it on the Advents. When I do hookups to the Bozaks, the receiver is shooting against the separates rather than other receivers. I start with an expectation that it will not come anywhere near sonically as satisfying and usually when I do this I'm right. I've done it with each brand I have including Sony, JVC, Pioneer, Sherwood, Marantz and H-K and while each receiver that I've kept is strong standalone in a system, it does not come near either set of separates. Well, until now. To start with, the Philips bears a strong family sonic resemblence to the separates. Not equal to in any way but comparing them and you can tell. Switching between the tuners (using the 6731 through the tape-inputs of the receiver) showed how strong the receiver's tuner is in storng stations in comparison to the 6731. The 6731 has better resolution, separation, better into the bass and high end but not by a large amount. Surprisingly on a folded dipole, the 6731 faired not better than the 797 in picking up distant stations but does have a faster quieting slope.
The weak piont on the H-K 630 seems ot be the preamp. THis is easily noticed when you use the power amp in the receiver with a decent preamp. The amp is excellent. In listening the the H-K after some time it seems as if something is slightly amiss. Almost there but not quite. I've heard this on every H-K x30 I've listened to. With the Philips the amp sounds as if it has its act together. Nothing seems out of place. Sibelence is not missing nore too strong. Bass easily comes forward when needed but does not overpower, very similar to my ARC D76a amps I had form some years as well as my Mc MC250 and MC2105. There is no lower midrange empahsis that I find on may units that seems to make the high end rolled off. Resolving power on strings is not as good as either the Mc not the Philips separates since it does not seem to deliver say the resonance of the violin or the sound of the sweep of the bow over the strings as well. Also on massed violin it walks a line between separating them into individual instruments playing together or a single massed set of violins. Triangle is the same on both Philips systems and slightly more glassy than through the Mc. Piano on all three does well but the Mc is the best of the 3 espacially the grand piano. The receiver in some ways actually does a bit better than the Philips separates in delivering the hammer strikes.
The phono section of the receiver is quiet and mates well with my ADC XLM MKII on my Thorens TD125. No sens of shrillness overload or anything bad in anyway. The noise level of the preamp is very very low.
When I got my Bozaks, my MC250 did not seem to have the juice to open them up so I got the MC2105. The 60 watts of the receiver did a really good job in getting the speakers to perform well. One issue I have with the Bozaks is the soundstage. These are big speakers and just deliver a wall of sound. I've had to live with an 8' high piano. The receiver lowered the soundstage to the top of the speakers which is about right for the piano. It does not have the depth of either set of components or the width and here the H-K is clearly better in delivering depth on these speakers but it too has an 8' piano. The soundstage loss took some getting used to.
I've left the unit on for the week running alternatively a minimum volume, at normal listien levels with the speakers off and at high levels with speaker off. The ambient temperature never varied and is only slightly above room temperature after a week, withing about 5 degrees on the case above the poer transformer while the heatsinks are not the slightest bit warm. This unit will nover have to worry about frying components from heat. The build is very neat and clean. Almost all wiring is below the chassis so when opened it looks so neat and tidy. The 3 boards are mounted from below the chassis and can be dropped without unscrewing anything so it looks very easy to repair unlike the amp which Echowars says is a horror.
I was brought up on tubes and separates. Most SS equipment is fatiguing after only a few hours of listening. The exception has been my Mc. Another has been the Philips components. As for receivers, save for the Mc receivers almost all are good for only a few hours at best. Even my Sonys fatigue me after some time. The 797 has not been. I've been listening for up to 8 hours continious (wife even brought food to me) and not a thing. I previously noted this on my Advents and Kipsch Heresys with the 785 and 796 receivers. The little 785 did nicely with the Heresys in this regard and those Herseys fatigue me with almost everything I've ever connected.
The power limit protection circuit is a voltage limited down to 4 ohms and then switches to 4 ohms. THe service manual states that wioth this design the output into 4 ohms will not be less than at 8 ohms but there may be some compression on high level peaks. This may be 1 reason why I heard some differnece in sound betwen my Advents (8 ohms) and the Smaller Advents (4 ohms) which were designed to sound the smae and my examples do hooked up to my tube systems and Mc systems as well as a receiver that is rock stable into 2 ohms. The differences are minor but if using Advents, at least stay with the original Advents and not the Smaller Advents since the 3db less efficiency of the Smaller will not be compensated for by having more power.
The 797 and 796 in earlier testing sound very very close. The 796 is 45 watts and the specs other specs are almost identical. One reason for this is that they use the same boards and mostly the same circuits. There is a smaller PS though the transformer is the same. I will be keeping them as long term units.
thanks for the thorough review of the 797 brian.i enjoyed reading it and glad you took some time to write it.regards,
chris
Just an update. A few months ago before chemo, I got my kid to swap in the 797 against the Sony STR-6120 that I got after this tread started. 2 different sounding receivers, neither right or worng, just different and both enjoyable. I think I like the Philips on the Symphonys but the Sony on the Wharfedale W70s. For those who think only 1 sound is correct try these 2 receivers and while you may find on a set of speakers is preferable I doubt you'll find either wrong. Can be spooky.
Also, an interesting study on build and quality; shows just how Magnavox/Philips cut corners on the visual but put layout and component quality into the interior. The Sony interior wise is no slouch but, the layout is not as repair friendly. A difference of years of production engineering possibly.
Hi Brian: I thoroughly enjoyed your post on the 797 - I did have one of these years ago and opted to "upgrade" to the 6731, 5781 and 5721 seperates - The 797 was a great receiver for the short time I had it and did find the tuner extremely sensitive and as you stated the reception using a dipole and antenna seemed to have even better reception than the 6731. My 5781 amp finally packed it in last year but I still have the 6731 tuner and 5721 pre-amp which i hope last another 30 + years ( they will most likely out live me) - I also had a N4506 for over 30 years and it finally packed it in last year as well. I was so impressed with the N4506 that I recently replaced it with a Philips N4520 which I imported from Germany and I must say it truely is Philips finest RTR. The sound quality of the N4520 is in a leaque of it's own when even compared to the N4506. Philips back in the late 70's and early 80's really did make some excelent equipment - I also have one of their CD960 CD players which is still regarded as one of the finest analog sounding cd players ever built. The quality they put into their equipment back then was truely impressive - It's too bad they never continued with it - I guess at the end of the day we can still sit back and listen and really enjoy the sound quality that this equipment was meant to provide us with. Good luck to you Brian!
Regards Wazy
I also have the pramp, amp and tuner; that's how I became reacquainted with the series that we looked at when I had my stores but, could not find a hole in our lineup for them.
The tuner and amp are doing well but the preamp is having an issue with a couple of the cap switches including the power switch. I think it is time to do a cap change in the power amps also. They were good enough that they replaced for some time my Mc system that I bought new decades ago and withstood a number of challenges from other companies. Good enough to sell the Mc system.
From there I discovered the receivers and finally a N4506 reel to reel/preamp. I'm actually impressed with the 4506 preamp. Rather versitile and good enough to use just as a decent preamp even if not using the tape deck. An oddball combo if there was any.
Not sure what packed in on your amp but, if you still have it, try to get it back into spec as it is one of the better I've heard and while there are some things I'd change if and when I get mine done such as changing the inputs to gold and the speaker terminals to 5-way posts, though neither give me any grief other than seemingly a cost cutting approach. Also, an IEC cord. The construction internally is very good and as good as most other amps I've had or seen the guts of. A tech here had an issue when he repaired 1 with the grounding configuration and an input filter that he removed and reconfigured but swore he'd never do another; he did not have or make the extensions to pull the boards to work on the amp.
The preamp is overly complex because of the cap switches that are dual-darlington and capacitor controlled and the light map. The reviews mentioned that as a result the original price was more than competing amps of similar quality. Today, it might be an advantage as the cap switches do not fail or become dirty, and the darlingtons and caps are apparently eaily obtained and replaced. At some point I do want to get it attended to but, it has to wait until I get back on my feet and when I do, I'll also update the jackset and install an IEC cord.
The tuner pointe is a bit off across th band, not a big issue. Again the jackset and an IEC cord would be in order for updating. The tuner is a close match for the MR77 but has more air and detail. It was a tough time trying to decide which I liked; almost a toss up after spending time with the tuners but, the AM tuner is so good in the Philips, it was the tipping point, the first AM tuner worthy of actually listening to in my main system. If the MR77 won out on FM I'd still have kept the Philips just for the AM.
The 797 is an excellent receiver in every way for my preferences and priorities. It has run head to head with my Sony STR6060 and 6120 both excellent and inho a pair of the best receivers from any company. The Sherwood SEL-200 may have been as good or slightly better but it needed caps to get back into fighting trim and someone wanted to buy it and restore it. I'm basing my thought on the S3300 that is the basis of the SEl tuner and the S9500c sound that I've been told is the same as the S9000 that I think is the basis for the amp section.
When I decided to downsize the inventory the 797 was not even considered to sell off. I did consider the 796 and 785 but, after comparing them to other receivers and even the tuners and integrated amps, I pulled them off the list, also. In the next round, the smaller receivers may again hit the list but I suspect that all others may hit the list instead and I may end up only with my Philips and Sonys plus the Sherwood receiver my son likes. Also, the non-Sherwood components and a small Sony pair may survive.
Hi Brian: Re Cap switches on the pre-amp - After you mentioned about these switches sometimes having an issue i went and checked all my pre-amp switches only to find that both the low and high filter switches do not light up or work - all other ones do and all the cap switches on my tuner are fine. I don't ever use the high and low filter functions so it's not really an issue however with my 5781 heading for the recyling depot I was thinking of removing the cap switches and possibly replacing the pre-amp low and high filter switches with the ones from the 5781. I am assuming these switches are all the same and am hoping it wouldnt be an issue to do this changeout?
I was also thinking it is a little odd that both the low and high filter switches are both out and maybe it's another issue? Any thoughts or suggestions you might be able to share?
Thanks Mike
The switch is not a switch as you think of them but an electionic circuit and the switch just provides a pair of metal contacts to make the circuit work. The switch itself is the darlington and cap that when the switch is touched changes value and activates or deactivates the circuit from my lay person's understanding of the manual.
Please do not junk the amp, PLEASE! They are rare and worth parting out for the transformer, boards, switches, etc. Have you had it checked by a tech and determined what work is needed. I'm not sure where Owen sound is in relation to Toronto but, if you do not want the amp, I could use it as a parts unit backup for mine (hope this does not violate an AK policy).
Good to see there is some talk on these Philips again, since they aren't that well-known. I agree they are very well-made, solid receivers. One issue that I have with mine is that occasionally one of the channels will sound significantly weaker than the other. Sometimes the sound will suddenly "come back" but more often than not the one channel completely lacks bass. I suspect this is a dirty contact issue, but one problem is that the volume pots, etc. are hard to get to without disassembling the front plate. No crackling whatsoever or cutting out when any of the controls are moved though, so I have a "feeling" this isn't the issue. I also suspect the relay contacts may be at fault - maybe I'll start there first?
Does anyone think a recap is worthwhile? I don't remember what the DC offset read last time I checked, but I want to say it was somewhere between 20 to 50 mV. You mentioned that these TOTL receivers rarely need to be serviced, but at this age I wonder if I will notice a difference by swapping out the capacitors.
