Thespeakerdude8
I'd been putting it off for a while and decided to finally finish re-wiring this zenith 7D31. All I replaced were the .1uf coupling caps and some out of tolerance resistors. The 12AX7's anode resistors, oddly enough, were all shot and tested into the Mohm region (original 68k.) All I had were 75k's, so thats what I used. The OT's are from a Conn organ amp (PP 7868's) and measured 6.6k A/A. I still have the original OT's and I want to try to figure out how to wire them up because the original configuration was very confusing.
The amplifier sounds very good actually, and has wonderful imaging and sound stage. It is also dead quiet and I can't tell its on, other than the heat it produces on my computer desk. The original circuit is a paraphase splitter, and I wonder if I should leave it as is to keep the Zenith heratige, or change it over to the Magnavox 6BQ5 version?
Wish I had a quad of mullards though :scratch2:
