Well I jumped into the Sparton the other day. This just gets more and more interesting. It is becoming clear that this thing has been highly modified by a previous owner. In some ways it was quite cleanly done while in other ways is quite amateurish. Fortunately none of it is buggered in ways that are visible or hard to remedy.
My first clue was the owners pamphlet which constantly referred to the controls in terms of left and right while my unit has controls oriented front to back. The manual also indicated that it came with a 10" speaker while the one install was clearly a 12" model. Couple that with the fact the the loop antenna could not be rotated as it was obviously intended to.
An auction on the Italian eBay site for the SAMS folder for this unit clearly showed a picture of a classic stand up radio with horizontal (left to right) control orientation. So some PO apparently chopped the top off when they added the 60s vintage record changer. The exterior of the TT drawer is quite nicely done and the mounting of the TT looks fine but the access hole in the bottom of the drawer is crudely hacked out.
When I removed the speaker I found that the new 12" driver was just screwed into the fiberboard baffle with the 10" hole unchanged. There is also no dust cap on the speaker so hopefully the fluff from the disintegrating baffle board didn't get in there to gunk things up as it looks like a pretty nice driver otherwise. Also note the glue that was allowed to drip on the cone.
Clearly the cardboard sided record storage cubby holes were added with the chop job as the right side one was interfering with the antenna. I intend to shorten that one enough to allow the antenna to swing properly. Hopefully if I make the new baffle board with the driver mounting as far left as possible I will be able to get the antenna swinging freely.
The rust on the speaker electromagnet and the condition of the baffle board indicate that it has been stored in some damp conditions.
The amp itself doesn't look too bad and was apparently working fine until there was a loud pop and the unit quit working.
My hope was that the caps in the RF and IF section would be of the long lived ceramic type like most other old radios I have seen. When I exposed the guts however it is almost all paper caps except for a few micas so it may be very difficult to avoid the necessity for a realignment. Unfortunately I have neither a scope or an RF generator so that could be an interesting problem.
I am not yet sure but it looks like those square metal things with screws in the middle of them might be variable capacitors which might be involved in the alignment process so if it turns out that these and the micas are the only ones in the RF and IF section then it might not be all that bad.
Here is a close up of one of the paper caps. As you can see it is kind of gunky and darkened. I don't know if that is from overheating, dampness or just ooze. In any case I plan to replace the can cap and all paper caps as a minimum. I suspect that most if not all of those CC resistors will be on the chopping block as well.
Well in any case a big job is ahead but I think it is worth it. However, given the amount of work ahead I will probably let this one simmer for a little bit while I finish my crossover amp.
mike
