SubWolfer
Well-Known Member
I have an older pair of Paradigm Bookshelf style speakers. I emailed Paradigm to find out the stats since I could not find any info online. How can I tell how much is too much amp (watts) for my speakers? According to Paradigm, my speakers have the following specs:
Design: 2 driver, 2-way bass reflex, Quasi-3rd order resistive port
Crossover: 4th order electro/acoustic at 1.6kHz
Driver Complement: one 25mm(1") Q25/XPT high-frequency driver, one 210mm(8") Q210/XPT bass/midrange driver
Performance: Low Frequency Extension 28Hz(DIN)
Frequency Response:
On Axis 0 degrees +/-2dB from 45Hz-20kHz
Off Axis 30 degrees +/-2dB from 45Hz-15kHz
Sensitivity-Room/Anechoic: 89dB/86dB
Suitable Amplifier Power Range: 15-150 watts
Maximum Input Power: 100 watts
Nominal/Minimum Impedance: 8 ohms/4 ohms
I'm confused by the fact that they say 150 watts is within suitable limits but then it says 100 watts maximum input power. I've also read not to worry, that even if you connect 250 watt amps you won't blow your speakers cause they'll never use that much. I'm looking for a decent SS amp to connect to my Parasound preamp to drive these speakers and could use a little help.
Frequency Response:
