basicblues
Well-Known Member
Working on a Pioneer SX-1980, power supply assembly board AWR-154. The unit works with good strong output but there's a hum so that's the main symptom.
It's always more difficult to follow behind someone who "rigged" one or more repairs on this board. Keeping that in mind, I'm dealing with changed parts.
As of right now I don't have the voltages I should have on one side. The positive side of the board is fine, I'm getting 30v to 35v on pin 9 and 12. The problem is with the negative side where I'm only getting -10v to -13v on pins 8 and 11 when I should be reading -30 to -34 volts.
Transistor Q213 was bad. When a good transistor is installed (On-Semi), R213 will blow and Q213 will fail. I thought that FET Q207 might have been compromised so it was replaced, same problem. Diodes D210/D211 both test good and Q209 was replaced, Q215 & Q217 both are good, even checked with new parts and completely out of the circuit, same problem. I've also double checked the foil traces and don't see anything shorted. So I'm missing something and need help to figure out what's going on and how to find the problem.
