...The VPI machines are made of wood and the fluids used in the cleaning process attack the material and make it look ugly. And I've read more than once comments from VPI users that complain of fluid spills and an underpowered suction motor. Now, if it spills water, make it out of molded plastic or aluminium. Somthing that can withstand the fluids.
I'm fairly confident that an experienced DIYer can make a much better RCM than the onces sold by various makers. IMHO, these "manufactured" RCMs are nothing more than average DIY contraptions with a substantial margin. Which is understandable as the market is small and isn't getting any larger.
Well, mine looks like new.
I'm not sure how messy some folks are, but I squirt the cleaning solution on the record, brush it well while it's rotating, vacuum it, and there aren't any splatters anywhere. It's perfectly clean inside the top compartment. I have absolutely no complaints about it, and I think the price was quite reasonable. Maybe one day I'll veneer the outside in bubinga, and change to a directional, hospital-grade cord, but for now I love it.
It isn't any noisier than any vacuum I own. I don't believe I've ever heard a quiet, much less silent, vacuum. Vacuums are noisy. All of them.
Underpowered suction motor?? It slams the suction wand down on the LP against the push of the return spring and holds it tightly against the LP while the LP is being rotated by the motor. Now, maybe the folks with this problem aren't spending much time doing the scrubbing, but they're running the vacuum way too long while doing 50 records at a time and the vacuum is overheating, but I've never had a problem, even while doing multiple records. Never.
DIY?? Do you want to make
one? Or are you talking about using molded plastic or aluminum or stainless steel and being able to sell it for $540 and still make enough of a profit to make it worthwhile? Give it a try. Members here on AK and on other sites have definitely done DIY RCM's. A few of them are gorgeous. First, turn on your turntable, push your finger firmly down on the platter, and see if it keeps turning while you're pushing. It stops, doesn't it? What kind of motor torque specifications do you think are required to keep the platter turning while you're brushing, and while the vacuum has the suction wand firmly attached to the turning LP? Take the total time spent, including the time looking for and sourcing parts and supplies, times $10/hr, plus cost of all materials, and see what you actually paid for it when it's done.
If you want to enjoy playing LP's, an RCM makes the difference between enjoying it, and giving it up out of frustration over how bad it sounds.
Keep in mind, an RCM won't fix scratches. I shake my head in dismay at some of the records I see people buy at the thrifts. Used for Frisbees, they were.
No, you don't use it every time you play the record. Clean the record well, put it in a new inner sleeve, and use a carbon fiber brush before each play.
I can't imagine listening to records (more than casually) and not owning one. It's one of the most important steps to making this hobby so enjoyable.:thmbsp:
