I had a fire in my fireplace last night and it started a chimney fire. Never had one before but you know you've got one when you hear that locomotive sound in your chimney. No other damage at least as far as I know but I've been advised to have the chimney inspected before use.
Unfortunately, my old, small (14" to 16" long) Winegard mast-mounted directional antenna (a Yagi?) that was mounted on a mast attached to that same chimney somehow no longer works. Looks fine from the ground but something is amiss now because my FM reception is horrible. It may be as simple as a melted cable, balun or connector. Regardless, it really didn't provide great reception anyway.
Anyway, I've had my eye on a half wave omni directional antenna from an AK Sponsor ( http://fmdxantenna.com/proddetail.php?prod=FMDipUS ) or a Metz (a single whip omni by the manufacturer of the Magnum Dynalab ST-2). I plan to install it on my other chimney about 10 feet away (boiler and hot water heater). The new location will also get it away from a nearby tree that has wreaked havoc on the unused TV antenna that shares the same mast.
Here north/northwest of Chicago I get some multipath but am interested in lots of stations in different directions so I think an omni is the solution for me. A rotor would be nice but yet another piece of equipment to buy, maintain and install and it adds yet another level of complexity.
I'm still considering a Winegard 6055 directional but am afraid it will not provide the reception of an omni without a rotor.
Any recommendations?
