How to use Multi Quote function
shacky
Addicted Member
OK - I failed the IQ test. I see how others use the multi quote function to parse someone's original message for detailed responses. Or add multiple quotes from different threads to one reply.
And I see the "Multi Quote thingy next to the "Quote" function in each reply.
But how the heck do you do it? :scratch2:
If you have more than one post you want to quote in your reply, click the multi-quote (it'll turn red when you do) on each post. Once you've clicked the multi-quote in each post you wish to quote, click the actual blue quote button which will take you to the advanced screen where you can compose your reply, and edit the quoted material down if you wish.
Interesting question and aswer... where do you click the multi-quote? I'm now in type mode and don't see it anywhere. Is it when hitting a reply? Is it when setting up?
Shacky....you're not the only one who's curious, I always thought it was done via tons of copy/pasting, didn't even know there was a feature for it.
whoa....NOW I see it, you gotta hit the multi quote (next to the "quote" button on each comment) prior to hitting post reply!
gotcha!
I suddenly feel smart.
In the bottom right-hand corner of each post are buttons for Quote, Multi-quote, and Quick Reply. If you don't know which is which, hover your cursor over each.
Here's a tip. The multi-quote button remembers the order in which you click the mq buttons. So, if you want the posts in the order in which they appear in the thread, click on them that way.
I've found the multi-quote to be a bit quirky on this and other forums that use the same software. Sometimes it works, sometimes I'll click on the multi quote button and it won't turn red. Seems like it's been working more consistently for me lately. I don't know if it is/was an issue with my individual computer, Safari in general, or with the forums. I run an older Macbook, Leopard, Safari. Just some FYI in case it is erratic for you as well... you are not alone.
Ok that helps a lot. But - when you want to take a post, quote it but split it up into multiple quotes/responses, how do you do that?:scratch2:
I just found it. Next to quote and looks like this....."+
Rob
gotcha!
Rob, you beat me to it!
I think I got it now!
There is also the ever popular nested quotes as well. Please note the irony I am not actually quoting myself.
Like this, Shacky?
Kinda. Let's say I want to take a reply (only one) and split it answering each section under the quote?
Thanks Shacky for asking these questions. I've been meaning to start a thread like this for some time now but just never got around to it.
The 'brute force' method is to copy it into the reply box, copy and paste it multiple times, depending on how many splits you want, then edit each iteration to remove the parts you don't want, in each quote box.
I am sure there is an easier method, but nothing is coming to me now.
[*QUOTE=shacky;3136931]OK - I failed the IQ test. I see how others use the multi quote function to parse someone's original message for detailed responses. Or add multiple quotes from different threads to one reply.
But how the heck do you do it? :scratch2:[/QUOTE*]
If you will look at the QUOTE commands, the one at the start of the sentence initiates the function and the one at the end finishes the command. Everything inside is quoted. Note that I added the asterisks so that you can see the command language. Your quote commands within the brackets should not have the asterisk.
If you want to insert a comment, you have to close the quote command, enter your comment, then reopen the quote command to continue with another quote, ad infinitum:
[*QUOTE=shacky;3136931]OK - I failed the IQ test. I see how others use the multi quote function to parse someone's original message for detailed responses. Or add multiple quotes from different threads to one reply.[/quote*]
Enter your comment here
[*quote]And I see the "Multi Quote thingy next to the "Quote" function in each reply.[/quote*]
Enter comment here
[*quote]But how the heck do you do it? :scratch2:[/QUOTE*]
To attribute the quote to a specific member, this is the part of the command in the first quote that does that:
=shacky;3136931
Make sense yet? Take a look at how the quote function works in your text edit window and I believe the syntax will begin to make sense to you. You basically have to initate the quote function and close it around the desired text.
This is what my prior post looks like without the asterisks so you can see how the quotes work:
Enter comment here
=shacky;3136931
Does programming ever make sense to us lay dummies? :D
Actually, this has been yet another educational session in AK. :thmbsp:
Regards,
D-Ray
