Fisherdude's "Mini-Amp"
Fisherdude
Regular Dude
Dave (dnewma04) asked me for some information about this amp. You can't add pics to a private message, so I thought I'd just toss the info in a thread. I had taken it with me to last year's AKFest just for fun, and had a blast taking it to different rooms and trying it with different sets of speakers.
Dave, sorry it took a few days to reply to your request, but believe it or not I couldn't remember where I put it!:withstpd:
Please understand, I never intended this to be a mahogany-and-brass work of art, it was simply a project for class. During the course of the semester, the class builds a series of little kits, strictly for soldering practice for the students who've never touched a soldering iron, and then for troubleshooting practice...for the students who've never touched a soldering iron. This particular kit was intended to be one of three parts. First, a little power supply, then a small signal generator that could display waveforms on a scope, and finally a little audio amp so you could hear the tones from the sig gen.
Well, I took one look at the specs on this little mono amp and went "whoa!!". So I asked the teacher (with whom I've developed a bit of a relationship, since we're exactly the same age) if I could have another amp kit. "What do you want that for? Stereo?". I replied "You haven't lived till you've listened to test tones in stereo!". He laughed and gave me another kit.
I put the two together in a simple plastic box, added speaker connectors, a standard 1/8" stereo jack, a standard DC input jack so I could run it off one of the 56 old laptop wallwarts I have, and away we go. I attached the two individual circuit boards back to back by their heatsinks, and attached them to the bottom of the box with some simple machine screws. I didn't include a volume control or on/off switch since I just planned on demonstrating it in class using an iPod, CD player, or some other source with a switch and volume control.
Here's what caught my attention:
3.5 w/ch RMS into 4 ohms, 2 w/ch RMS into 8 ohms.
20 Hz - 20 kHz @ -3dB.
0.05% THD @ 1w/1kHz.
86 dB S/N (A weighted)
The kit is a Velleman K4001. You can get them everywhere on the net. Here's a place that has them on sale:
http://www.designnotes.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=K4001&Category_Code=auha
I brought a pair of Paradigm Mini-Monitors to class, put on Muddy Waters, and blew everybody away. Students and teachers were coming in from classrooms on both sides!
These certainly won't produce room-filling volume with low sensitivity speakers, but they most definitely will provide normal listening volume with amazing fidelity. I tried to shove some Indignias pretty hard, and the amp will start to clip. However, hook up some 90+ dB speaks and it's jaw-dropping. I put the iPod in the pics just for scale, but the dock is line-out, so you couldn't use the dock because it bypasses the volume control. If you wanted to get fancy, add a 47k stereo pot with an on/off switch, nicer box, and you're good to go!
The cost of the two kits, plus the other bits and pieces is close to what you'd pay for an original T-amp, but I have one and I really think this little guy sounds a lot better. Plus, I think it's a lot cooler, and it's certainly a lot more fun!
Hope you like!
Clay
I heard it at the Fest and was impressed. We had it in the DIY room running the Bob speakers and it was fantastic. We unhooked a hotrodded ST70 tube amp and a Nelson Pass F5 class A SS amp to run this little guy and it held it's own until you clipped it.
Very cool, Clay! Can't wait to hear it some time.
Clay, didn't you have it at the last Chicagofest? I thought we had it hooked up to your little RS speakers at one point downstairs. I think you may have heard it Bob.
Maybe someone set a CD on it and hid it from view.
Nice!
A little info needed 'cause I'm curious...
Do i see correctly, only one active device?
What transistor(s) (see above) is that?
Is it simply a current buffer amp, or is there some voltage gain?
If it is just one transistor, it has to be single-ended and class-A, sweet!
az
This little gem played Friday night at the 'Fest in my room, on the Cornholios. It had great bass, and was a wonderful sounding little amp. I was impressed at it's ability to drive the Cornholios. Neat amp, Clay!
You know, I forgot about that!
Nice!
az
The active component is a TDA2003 IC. It's both thermally protected and short-circuit protected.
I'm sure I could post the schematic, if there's any interest...
Damn, I must have been upstairs at the time. Pretty embarrassing when it was in my own house and I missed it. Looking forward to hearing it nonetheless.
If it has 4 7591s perhaps they'd work in my old MA-230 too.
Consider this interest, please.
Here you go...
Power required is 8-18 VDC at 0.5A. I used an old 16V IBM laptop wallwart, and it works great.
