I purchased this receiver a couple years ago from Ebay. Blown right channel had been replaced with NTE1281 at that time. About 1 year later, I recapped this entire unit and had been working well ever since. I had been using headphone before without problem and it had been awhile since I used headphone. Finally I decided to connect the headphone then release the speaker button and noticed my left channel meter moved up to a few watts. Pushed the button back in then meter returns to zero. I pulled it out of service due to suspicious oscillation. Putting it on the scope with 1 microsecond setting, I found it oscillating approximately 3 1/4 mhz at around 3 volts output(see pic). I checked the feedback resistor and the disk capacitor, both appears ok. Checked DC offset and appears good. Bias checked at zero even though no adjustment for it. Upon researching and found a thread about SX-680 oscillating (not SX-780 with different topology), I have considered either swapping modules but don't like to do so unless really necessary. Also have considered pulling the module out of my other SX-780 (need repair anyways) to test any changes but wouldn't want to take apart my other SX-780 unless really necessary either. Any pointer for me to look at? Would it be the faulty modules?
EDIT: After writing the above, I decided to check with my audio generator @ 10khz approx 1 watt @ output:
1st pic: described from above as an oscillation waveform ("L" channel).
2nd pic: Sine on "R" channel (not bad for NTE device)
3rd pic: Square on "R" channel
4th pic: Sine on "L" channel original module (ringing crossover distortion)
5th pic: Square on "L" channel
6th pic: Sine on"L" channel (o-scope speed halved to see - to + swing)
Does that look like a faulty output module?
Thanks.
Thanks.
