Jonesy09
Part warning, part inquiry.....
I ordered this knowing I was taking a risk (it was an epray buy, not from this site at full price). It dosen't fit. That's the warning part. Any PL-41 owners looking at this piece be aware. It will not just slide on in place of the stock cable.
Now the inquiry part.
Initially, the actual pin holes on the cable end looked too small, and they were. I was able to spread them via the relief slits, and after fitting each hole on each pin, was able to determine that they would indeed slide on. However, it seems that the spread of the pins is just a bit off as I can't get the entire DIN connector on the pins.
This is a nice cable and I want to make it work. Right now the only way I can see this happening is reaming out the DIN holes on the connector. I have no idea what effect this will have on the performance of the cable. I don't even know it it'll work.
If that fails I could certainly clip the RCA's off the Canare (they're nice and beefy) and put them on the stock cable. But again, I don't know if that will be an overall improvement. It would certainly be an improvement fit-wise over the current mismatched connectors and iffy soldering.
Or I could just try to send the thing back (to Israel).
What'dya think?
What'dya think?
