Jonesy09
So my parts came in today and in looking over the tonearm a couple questions come ot mind. First, is there a particular secret for getting the existing male DIN out of the tonearm base, or do I just pry it out? It dosen't appear that it's going to come out easy and I wanted to check if there's an obvious solution before I go banging on it (I'm very good at tearing **** apart - particularly so it's never usable again). :bash:
Second, I removed the two tiny set screws that are on the underside of the arm next to the headshell collar. I'm assuming that piece will pull out given enough force, but want to make sure. Same as above.
