Sherwood ST-903 Nudies
malanga
Well-Known Member
Hi All.
As I posted on another thread, I picked up a Sherwood ST-903 Linear turntable yesterday. It has the same size belt as my Pioneer, so i swapped them and the turntable was spinning, but the arm did not move. It was not working so I decided to open it up and take a look.
Here she is:
Sorry for the blurry picture. The cartridge is an Audio Technica M13 E/U
Okay, so I took the cover off. Here is a pic of the linear arm mechanism.
Everything seemed to move fine, but the arm would not do anything. I decided to examine the motor for the arm:
I touched the spindle of the motor and it was spinning:
The belt was so loose that it did not even move. Now where have a seen a belt like that before...oh yes, my daughter's rubber bands for her hair! I went and got one:
Would you believe the bloody thing worked! She is playing like a champ now!
I played the album to the end and it sounds solid! The only possible problem was that the arm did not return at the end of the record. I do not know if it was supposed to however. As far as I can tell all the other functions were just fine. Don't you just love happy endings! :thmbsp:
Clean and lube sparingly. Proper belts will help. The plastic looks as though it has aged. You may need to clean the pulleys a bit? Nice project though - have fun :)
Yes, I do plan to get the right belts eventually. The plastic is okay, just bad pics from my cheap camera!
Even though this thread is dead I'm still hoping maybe somebody has a hint for me... I just had this same turntable given to my by my grandmother and it has the same issue as this one does but when I don't get any output of sound at all... I can hear the music if I stick my head close to the needle and I know it's not my amps... Any ideas?
My best SWAG is that it is not unmuting on play. This can be a failure of the muing ckt or failure to complete play cycling with the cueing. It looks from the pic like the cueing/muting mech may be on the arm sled.
I'm not really too sure what you're talking about is this something I can fix without replacing parts?
Probably yes. Follow the signal leads in from the RCAs to the arm sled, the muting thingie will be along there somewhere. It's basically a shorting switch to keep cycling noises out of the sound during cue-down/cue-up and track finding.
