Onkyo CP-1026A turntable
lmccay
I have bought a vintage CP_1026A. I know nothing about adjustments of the tone arm weights. I bought it off Ebay and he said it played for him. it is playing but the sound is not the what is recorded on the album. It may need a new needle. does anyone know how to adjust the tone arm, and where to get a new needle. Thanks
Larry McCay
Hi,
Welcome to AK,
There are posts that explain the "0" balance of the tonearm and how to setup your Onkyo. Just do a search and you will find what you are looking for.
If the belt is good then all you need is a stylus or needle for the cartridge that is on the tonearm now.
www.vinylengine.com has some good answers too.
Thanks,
John.:music::D
You need to look at the cartridge and tell us if there is any lettering or identification on it--or--post a picture of it. Only after knowing the cartridge can you know what tracking force to use to play it. So it may not need a new needle--it just may need to be set up properly.
Vinylengine has the manual for the CP-1010A, which is close enough for setup purposes.
Also, this needs to be plugged into a PHONO jack of an amp, preamp, or receiver. The AUX input will not work.
I will get a picture and post. It is plugged into the back of the receiver where it says Phono. thanks a million.
I downloaded the manual for CP-1010A, and followed the instructions. Setting the weight to "2" and the anti skate to "2" caused the tone arm to skip across the album very fast. I tried different settings and can get it to not skate across but the sound is not the music on album. The stylus that is in it is an empire LTD 450. I am going to upload pictures if I can figure out how to do so. Thanks again for all your help and interest in solving someone else's problems.
How could you tell that the stylus was shot. You must have an eye for this. I could not find a # on the stylus itself but the LTD 450 was the cartridge, is that correct. I know nothing about these things, just learning. What is your recommendation for setup weights since "2" did not work.
Maybe it would not track right because the stylus is no good. Does anyone know where I can get or have a manual for the CP-1026A
