JustinP
Got this receiver for free, saved it from the trash! Would have been a complete waste had I not saved it. First test to see if it works, all good. It powered on, only a couple front panel lamps seem to be burned out. Connected a pair of (basically worthless) Aiwa bookshelf speakers and started testing each source. Output is good, all sources give an output.
Now the bad :tears:
All sources have A LOT of static/hiss in the high frequencies, especially when volume at 25% and up.
The PHONO input seems to have been shorted by too high a signal being fed into it. This is very audible at any volume.
I'm guessing it has a DC offset problem, there is a 0.5v difference in output power between the left and right channels. Right channel has a very scratchy/hissy sound in the highs. Best I can describe is it almost sounds as if the amp is clipping, even at rather low volume.
Probably would greatly benefit from a good cleaning.. DeoxIt Bass, Treble, Balance and Volume. I was told over on Parts Express Tech Talk that I may want to consider re-capping. Also I've heard some of the Sansui's had very problematic Dolby boards that can wreak havoc on the whole system. This one may be suspect there as well.
Any suggestions?
Thanks
Now the bad :tears:
Any suggestions?
Thanks
