OscarEmmy
VHFSE Originator/Blogger
New to tubes, and this is the first of two projects (other is a full restoration of a Telefunken Opus Royal tube radio/phonogram...down the road a ways, as yet). Project 1 is to get a Magnavox AMP 169 AA mono turntable amp working. The design of this is one where the amp power connection is switched on from the turntable. There is a 3-wire push connector (I have no Magnavox turntable), with a red, yellow and black wire - presumably two of these need to be jumped to make the amp turn on? Which ones do I jump together? Naturally, I will fit a switch to the amp eventually. I am including pics of the amp (when removed), after cleaning, and detailed shot of wiring at the TT connector/romex plug.
Any advice would be appreciated. As yet, I have no idea if this amp even works. I have the speakers that came with the console.
. For a little amp, even with no enclosure for the 4 speakers (1 x 15 inch, 2 x 4 inch and 1 x 8 inch), it has not bad volume. When not distorting it really does sound sweet! Definitely worth fixing up to use as a 78 rpm mono amp (the stereo amp for my main 33.3 turntable will be a different project, using the Telefunken console tube amp).
