How to calculate in-line speaker fuse size?
mrbruce
AK Subscriber
My specific issue is what size in-line fuses to use between an Adcom GFA-555 (325 wpc at 4ohms) and a stacked pair of New Large Advent speakers wired in parallel (nominal 4 ohm load). The speakers can probably stand an instantaneous load of 100 watts - although I don't plan to get near there. The Adcom doesn't have any speaker protection installed, so adding something is a rational approach.
More generally, I'm interested in the math to figure a fuse size for a given "allowable" output to a given set of speakers from a given amp. I would be grateful for anyone who could walk through the calculation process and the variables that need to be identified. I also need coaching on whether the fuse goes on the positive or ground leg of the amplifier outputs. I assume whatever size fuse is calculated would be a fast blow but not really even sure of that.
Thanks in advance!
Bruce
Well, you're going to need to know the impedance of your speakers.
From that and your highest power limit (100W) you have your two things to figure current.
I=sqrt(P/R) ~3.5 A for a 8 Ohm load, 5A for a 4 ohm load, etc.
You can set your power limit lower and still get away with 100W peaks without blowing fuses. It takes a little time for the fuse to blow at it's rated current.
Ohm's Law rules. I squared times R equals power in Watts. For 8 Ohms, 100 Watts, you divide 100 by 8 and take square root of the 12.5 result. So the current would be about 3.5 A. Use a 3 or 4 A fuse for that. And so on.
the correct fuse as recommended by The Advent Corporation is an FNM 8/10 for each speaker. however, a fast-blow 3 amp feeding each double pair works just fine.
Thanks SpruceMoose. I had just settled on exactly that fuse. Based on what I've read elsewhere, looks like these should go in the minus side of the speaker wiring. Unless someone says otherwise, that's what I'll do. Assume it makes a difference but don't know.
Bruce
Bruce
It doesn't make a difference. Anywhere you insert the fuse into the series circuit results in the same effect.
I checked out the nomographs suggested by 70salesguy and kcollins4. Although the nomographs seem to agree with other, they do not agree with the math formulas given by Jon_Logan and Bob91343.
Nor do the nomographs agree with
Ppeak = 4 R I^2
where
R = speaker impedance
I = RMS current
Ppeak = Peak music power = 4 time continous "average" power.
The above equation seems to work at low current (1 to 2 amps), but gives Ppeak too low for the higher currents.
I'm still digging into the physics to determine the correct formulation.
Yeah, I'm not quite sure how that nomograph got it's values. The content of music may be a clue, where these values may be empirically based.
Since the average level for music content may be about 20dB below the peak value, running an amp with peaks of 100W (28.28V for 8 ohms), 20dB less would be about 1 W (2.82 V for 8 ohms). Music doesn't have a constant level and fuses do take a certain amount of time to react. Under-fusing, until you settle on a good real world value maybe the way to go. Start lower and increase the rating until you're satisfied it'll let you play loud enough without blowing.
This is the ONLY way to go. Did this with a pair of Yamaha NS-1000Ms driven by a Yamaha CR-2020 - blew the 1amp fast-blo but the 1.5amp fast-blo doesn't blow with the volumes I listen at (I'm in a dedicated listening room AND can turn it up pretty loud:D).
Fortunately my system does not need a fuse- for two reasons:
1. My amp (Yamaha RX-797) only puts out 100 watts "RMS" into 8 ohm and my speakers (Klipsch RF-7) can handle 250 watts.
2. If I did have a 500 watt amp, my ears would blow before my speakers blew. Then I wouldn't need the speaker anymore.
I know this is a very old post, but since I landed here after a search for something else, figured others probably end up on this post as well, so gonna add something. Music with lots of extended peaks, or say constant bass, etc. played loudly can easily exceed those fuse ratings depending on how dynamically robust the amplifier wants to act.
For example, a small amplifier from my high school days which ran 2N3055 outputs and was rated @33 wpc @8ohm, had 3 amp in-line fuses for protection per channel and a rather large transformer that had a 290w rating. Other than a large AC-powered PC fan (think it was roughly 5") custom added to the case to pull heat OUT as those little guys could get hot, that unit was untouched internally. It had the ability to pop those fuses under loud volumes. I wasn't clipping the amp then either, but was very near that limit. I ran two 3-way cabs with 12" woofers (8 ohm) that were cumulatively rated around 150w rms each, which they definitely never saw from that amplifier. Would run the loudness switched on (it's an active circuit, not passive) and bass at +6 db, while using the AUX in and a CD player, and listened to rap from 92' to 93' which was basically all bass.
Anyhow, 3 amp wasn't enough and I suspect the amplifier might have been peaking around 50-55 wpc. It took 4 amp speaker fuses to allow it to handle that stress. The unit's main 3 amp fuse never blew, just the speaker ones on occasion if doing extended "rattle the neighbor's walls" runs.
