Finally my Hybrid G-7700 is working properly!!
kevzep
Its all about the Music
Some of you may have been following my Hot-Rodded G-7700, with the output section I had to fabricate from, well, nothing.
I thought i was home free with this amp, but NO, boy was I in for a surprise.
I had the Toshiba 2SC 32381/2SA 1302 OP's which came my way for free after I blew up the NOS Sankens when I fired it up with the trimpots on the VBE multiplier set the wrong way, and the Multimeters measuring the bias current both set to AC instead of DC.
I went with the VBE multiplier because I thought it would be an elegant way to regulate the bis current.
I went with the MJE15032/33 drivers as I assumed the original ones were toast.
I set bias, ran the amp up a few times, and reported the insane amount of power coming out of this amp on a thread recently.
I had the amp running for a few weeks mostly at low levels, but then the other day I decided to play some loud music, when I did I put my hand on the heatsink and just about received 3rd degree burns, holy crap the thing was running hot, I could have fried my dinner on it.
So I thought okay somethings not right here. I put the amp on the bench again to study the bias current. I had mounted my VBE transistor on the heatsink for thermal tracking, so I couldnt understand why the amp was running hot. The idle current was a couple of mV above the manufacturers spec but it still didnt explain what was going on.
Okay, so I put an 8 ohm load on the amp, with a 1k sine wave and wound it up. To my horror the bias voltage just sky rocketed, up to over 200mV, and took out 2 emitter resistors, one OP, fried a base resistor on one of the class A pre-drivers, blew open a base resistor on the OP which blew.
Holy Crap.
There was a fairly impressive mushroom cloud from that meltdown!!!
I fixed everything and tested everything in the driver stage, to my surprise the driver transistors were okay.
So we were up and running again, now this time when I was setting the bias I noticed some high frequency oscillation following the sine wave, I dont know how I missed it before but when I got to the optimum bias current it was reduced. I put a 1000pf cap across the Base and Collector of my VBE transistor thinking it may help with the HF Oscillation, but no such luck.
Next thing I did was to check the thermal tracking of the bias, I took the vbe off the heatsink and while monitoring the bias current, pinched the transistor between my fingers, and as soon as I did I could see the current go down, great news I thought, because I suspected this was not happening.
But what the hell with this skyrocketing current and the HF oscillation??
I went through everything over and over and over and couldnt come up with an answer.
Was it these OP's? I didnt think so..........
I improved my thermal management in the heatsink department, by adding a large alloy plate which I bolted over the top of the OP's with thermal paste, to help dissipate more heat.
The other thing happening was the horrendous crossover distortion, which required way more idle current to correct than it should have.
Clutching at straws I decided to test the original 2sa968/2sc2238 driver transistors, to my surprise they tested okay, so i put them in.
Hey bloody Presto, the idle current was majorly reduced and very stable. Also the HF oscillation was gone.
Even at a few milliamps there was NO crossover distortion........
So I set the Idle current and DC offset, I went at 17mA which is about what the original spec is I believe.
I ran both channels at almost clip, and yes this was about 41VRMS for about 10mins.
The OP's were warm, not hot and the bias current was stable.
I put it back in to service............
So those driver transistors may not be a suitable sub, I know guys have used them, I used them on the recommendation of a couple of members but it looks like there could be a incompatibility issue there. It could be something to do with the OP's I used perhaps.
I have been listening to this amp for the last couple of days, and it is by far my favorite, this thing has BALLS and crystal clear BALLS at that.
I actually cant get over how good this thing sounds, Im running it through my JBL ES90's, I even pulled the faceplate off deoxited the switches and pots cleaned her up.
The VBE multiplier is a very good way to regulate the bias current, its very easy to do. All you need is a MJE350 a 1K5 resistor, a 470ohm resistor and a 1K trimmer and you're off. It's a bit twitchy with the fine adjustment, but I think I could change some of the resistor values and make it a bit less sensitive, but its not as twitchy as setting the DC offset, and I didnt have any trouble achieving the current I wanted so Ive left it.
I will scan something in the way of a schematic next few days and post it if anyone's interested.
Now I need something else to resurrect!! Man did I blow some **** up doing this but it was all in the interest of research and development, and reviving an awesome piece of history!!
I hope what Ive learned will be of use to other members one day.
Im a happy Dude!! And listening to Led Zeppelin right now!! And quite loud too!!
That is a magnificent effort - you can feel rightly proud of yourself - well done indeed. :thmbsp:
Just notice you have updated your sig - lol :smoke:
Thank you John it was a real journey of development, yes I thought this time with the amp performing as it does now, it earned its spot in the signature!!
Just proves that "beyond repair" has a new meaning for me!!
That is a very impressive repair.
I too like that series of receiver.
Rob
Thank you Rob, during my journey I began to resent the G-X700 series, but perseverance brought me back on track.....especially when it fired up and I got to actually hear it..........
I think the 7700 is a real dark horse, overshadowed by the 8700 and the 9700 it seems they are often overlooked.............
Far Out! What a journey that G7700 has led you on :yes: At least you've finally got it sorted and running properly, funny about those drivers causing the oscillation, one/both may have breaking down under load..You never can trust them silicon devices sometimes....
Cheers
Glen
Cheers
Glen
Yes it has, Im pretty sure it is sorted now. Im not so sure about the consistency of those drivers I was using, I tested them on my transistor tester and they all had quite different hfe, even the MJE350's all had varying hfe , lucky I ordered quite a few of the 350's and had enough to mix and match and have them all fairly close.
But the drivers yeah Im not sure what was happening there............maybe they arent fast enough or something............
I wonder about quality control on such mass produced components these days.............
Good job Kevzep!
Thanks for taking the time to share the experience with us, we all learn from such events...
Good job Kevzep!
Thanks Casey, well when I came to this forum I enjoyed reading and learning from the journeys other members has experienced with repairs and rebuilds, I still do. One can learn a lot from such experiences.
What a crime it would have been to part out my G-7700 and give up on it, I hope other members are inspired by such threads.
Now Im wondering what my next mission will be..................I will take anything on now!!
