Alright, first post. So i just got this Teac 4-track, i got it real cheap.
I cleaned the heads very well with q-tips and 99% Iso. Alcahol, because they were covered in a THICK layer of sticky tape shed, and nowthey are perfectly clean. They have a little bit of wear, but I don't think its that big of an issue.
Ok, so It works great, but the problem is that the Front-Left, and Rear-Right channels (track 1 & 4), sound muffled and have a slightly lower output. This effect only happens on things i record, but they'll playback other tapes just fine.
(affects both Mic and Line inputs)
So, I'm wondering, does this have anything to do with the record head? is it too worn? I think these are the edge tracks on the tape, is it possible that the tape I'm using doesn't line up with the wear pattern of the tape heads? or could this be an "internal" problem.
Whatever the case is, I really don't want to take this to a tech. Any help out there?
I've got 2 mp3's track2(clear), track1(muffled), but no way to upload em.
