surfdoc37
Endlessly Endless End
OK, time to go through the boxes and piles of tubes I've gathered and stuffed away, and I have no idea which ones I should keep and which should leave.
I just want to sell the whole group together, but keep the good audio amp tubes. Those will either stick around or leave separately. I suppose I could take a look at my Sherwood, Fisher, and mono amps, but this is more fun, plus you guys know your stuff.
I may or may not have some good ampers, but likely have close to a thousand +/- or more tubes, don't even know, most new in the box. I think most of the guys I bought inventories from were into radio and TV repair, so probably mostly that's what I'll find.
Without going too extensive, common amp power tubes or other heavyweights to look for? Thanks :thmbsp:
I just want to sell the whole group together, but keep the good audio amp tubes. Those will either stick around or leave separately. I suppose I could take a look at my Sherwood, Fisher, and mono amps, but this is more fun, plus you guys know your stuff.I may or may not have some good ampers, but likely have close to a thousand +/- or more tubes, don't even know, most new in the box. I think most of the guys I bought inventories from were into radio and TV repair, so probably mostly that's what I'll find.
