kfa888
Addicted Member
Well I just had to grab them. I've had the matching sub (s) for years. Don't come up much. Made in the USA (late 70's?) M&K sat-1 speakers. Time aligned I might add. They are bricks, thick cabs, lots of wood. For small speaker they are heavy. I have a passive Goliath M&K sub or powered Volkswoofer MK sub, both peirod correct and very similar look. Will try both and pick. Some cab damage but not bad, will clean up nice. :thmbsp:
I have the original drivers but the owner said they sounded floppy and loose. Surrounds look good but suspension does feel loose. Anyway i have them. Anyone know who actually makes the MK badged speakers?
Replacement are Vifa (or peerless maybe?)... heck, you guess. Coated aluminum. Sound pretty good and surprisingly powerful for small speakers.
Has a mutli speaker hooks up that changes the sound and it actually works amazingly well. NICE. It is access to an internal XO with varied settings. Has the diagram on the rear of the speakers. Six settings, German, British, American and high / low tweet for each. Fun. Off my little pioneer and i preferred the German / Low setting but did not try the American / hi which the seller preferred as i needed a jumper and had no time. Will be fun to play with.
So heard them at the sellers house and sounded good. Sounds good here to. Have not run them with a sub so can't really form an opinion yet. Once they are released from low end duties and there IS low end I think it will be quite good. Like the tweets already, mids are nice too and the whole thing is "punchy" sounding. Should be fun.
BTW why would you stack tweets?
Badges and everything.
Tight and punchy with great top end and not much bottom.
