gonzothegreat
Long ago I rebuilt a beater Kenwood 700m with lots of help from EW. One thing I didn't do at the time was replace the four rear outlets because I didn't have a source for the parts. I just bypassed the outlets and made sure nothing would short out. Time marches on and I eventually ordered some plastic snap-in outlets. A few nights ago I was itching to do an easy audio project. I grabbed my 700m and hauled it over to the bench. Once I removed the back panel, I realized this might not be so simple. After scratching my noggin and inhaling too many solder fumes, I searched AK and found this post.
http://www.audiokarma.org/forums/showpost.php?p=2698184&postcount=37
(Echowars' rear wiring diagram for the 700m)
Here's what froze me in my tracks - the original power cord and outlets are non-polarized while the replacement outlets are polarized. Just to make things more confusing, it appears that at least one of the outlets swapped hot and neutral (specifically the second non-switched outlet). I can't even tell if the switched outlets were wired correctly (ie neutral blade on the left and hot blade on the right) because I removed said wiring and didn't take notes.
Can I just swap the wires on the second unswitched outlet or do I need to do the same to the switched outlets?
Just for the record I don't ever intend to use the rear outlets but I'd like to get it wired correctly so I never have to screw with it again.
