Dan ʕ•ᴥ•ʔ
Peanut Head
I have a Music Hall turntable which has a decent phono preamp built into it. Now the preamp only has 150mV of output, but it can be bypassed to go direct from the cartridge. I'm assembling a passive line stage level control and switch box for it, my CDP, tuner, etc. As I see it, I have two ways to go, I can either get a different phono preamp with the needed 1.5 to 2.0 volts of output, or I can simply build a small gain stage to go between the turntable's preamp and the switchbox to get the extra gain I need.
I'm on the fence on which way to go with this. What would you do?
The Music Hall TT has a built-in preamp, and it's response isn't exactly flat. It's +1dB @ 20Hz and -3dB @ 20kHz, that may be enough reason to get a different preamp and be *ready to roll* if I later decide to get a different turntable.
