Hello,
I asked Mr Bob Crites about it and he replied that I'm better calling Electrovoice directly.
However, I'll take achance here first.
Copy and paste of the mail sent to Mr Crites:
Hello,
I'm curious to know if you have some CR-35 crossover schematic available (8 ohms)?
I want to rebuilt mine because I'm not sure that the 50 years old caps in there performs as they should. I hear some harshness in the mid/hi range. This is with the following components:
- 2 custom big boxes loaded each with an EV SP12B and a TW35 (8 ohms);
- the speakers are feeded with an Eico HF-81, freshly rebuilt (all caps and resistors).
Sure, the fact that the Eico has now some modern caps could brighten the sound but at least, by building a new set of xovers, I would be able to compare...
Stupidly, I've bought a replacement set of CR-35's on the Bay, thinking that I would open them and just replace the caps, but it looks a tedious job as those things are completely closed and as I heard, filled with black tar inside.
So, I would be better to build them from scratch.
The only approaching schematic I've found is located here: http://www.users.cloud9.net/~pastark/ON63f123.jpg. It's a CR-35 schematic that came from a Schober organ thingie so I'm not sure if the xovers are ecaxtly the same as mine.
What made me doubtful (about the values of the xover in the organ) also is that I've entered the parameters of my drivers on an online xover calculator ( http://www.ajdesigner.com/crossover/crossoverfirst.php ) and ended with 5.6 mfd and 0.37mH. The guy with the Schober has 2.8 mfd and 0.37mH in his CR-35...
**I could also play with my Lpads as I remember having set them at full treble when I acquired the speakers (one year ago). However, they are inside the boxes and I have to unscrew the back panels and fiddle inside the cabinets to reach them (did I say "custom made"...). Lazy me
Thanks.
Patrice
The Electrovoice speakers in question were discussed here last year:
http://www.audiokarma.org/forums/showthread.php?t=282177
Thanks a lot,
Patrice
Hello,
Thanks.
Patrice
Thanks a lot,
Patrice
