On the subject of Coral Speakers, just snagged some BX-201s. Look just like the more-common BX-200s, but can't find any specs on them.
I doubt if there's significant difference. Here are BX-200 specs:
BX-200 data from
http://audio-database.com/CORAL/speaker/bx-200-e.html
System 2 ways, 2 speakers, a sealing system, and a book shelf type
Use unit
For low-pass : 16cm corn type
For high regions : Phon type
Impedance 8ohms
Play frequency band 50Hz - 20000Hz
The maximum input 15W
Crossover frequency 4000Hz(6dB/oct)
Output sound pressure level 98dB/W
Dimensions Width 268x height 368x depth of 220mm
Weight 4.5kg
One difference: the label on the BX-201s claims a maximum "music power" input of 30 watts, but it drops the '15 continuous' spec. A marketing revision has happened, at least. Identical frequency response specs remain.
Drivers look very similar, but Coral branding and other specifics have been added to markings. 2 mfd crossover capacitor is unchanged:
