Successful recap my beloved SX-780, some tuner questions
Uncle Bambi
Funky Tut
I bought this SX-780 new in 1978 or so, from Pacific Stereo in Canoga Park CA. It was my main stereo receiver for years and years, and has been a steadfast friend and great performer. It would be safe to say that I'm emotionally attached to it. :)
Back about 10 or 12 years ago, when Surround Sound was the Next Big Thing I just had to have, it went into the closet and sat dormant up until this year when I needed a good stereo for my office. So I dusted it of, fired it up, and started doing a bit of research...... which led me here. OK - I learned in pretty short order that I should be concerned about the aging electrolytic caps and decided that it needed to be done.
Reluctant to learn on a receiver that I was so attached to, I bought a sick SX-838 for cheap and used that as my test bed. Thanks to the technical sharpshooters here that held my hand and put up with my noob questions, that SX-838 is now my kick-ass garage stereo. Wanting to hone my skills, I bagged a functioning but in need of TLC SX-650 on the local CL and went to town. I had that one singing in pretty short order, and was now ready to restore my baby.
Luckily, the SX-780 was a very popular receiver and is much discussed here. That made the task pretty straightforward, and because I had cut my teeth on the much more complex SX-838, I was able to literally run though the SX-780, re-capping it in short order with zero issues. I plan on doing the heat-sink upgrade, and found a nice pair of Nichion gold filter caps for the power supply that will go in when they arrive. It's been de-oxit'ed and faderlubed, and DC offset is near-zero, and it is purring along as I type. :music:
OK - if you've followed me this far, I've got some questions regarding the capacitors on the tuner board (I went though this with the SX-650, and learned enough to be foolishly bold). Because many of the caps were bulged, I went ahead and changed out most of the tuner caps without any ill effect. Now, here's my question - the ones that I DID NOT touch are directly connected to the PA1001-A IC. They are:
C35 22uf 16v - connected to pin 1 +Vcc
C37 50v 6.8uf - connected to pin 14 PLL L.P.F.
C38 50v 1uf - connected across pins 13/14 PLL L.P.F.
C40 50v 1uf - connected across pins 10/11 Pilot Out
C41 50v 1uf - connected to pin 9 Quad Out
My question is should I replace these, or did I get lucky so far and should I leave well enough alone? C37 especially - 6.8uf? That's such an odd number that it really gave me pause. In case it matters - all of these caps are orange in color, except C35 and C41, which are navy blue.
It looks like all the RF stuff is on the HA1197 chip, but looking at the PA1001-A internal diagram I see stuff Like VCO Frequency Adjust and Phase Comparator - so I thought I should ask. :D
IMHO, replacement of the electrolytics in that part of the circuit should be safe. Use low leakage, low tangental loss factor devices with a reasonable (10% or lower) tolerance and the system should work as intended. My suspicion is that if you were to actually test the devices now installed and are presumably working acceptably, they would be at least 10% out of design tolerance. Nichicon and Panasonic offer bulk devices which are more than adequate, and 6.8µF is not that uncommon. A quick check at Mouser shows at least 20 types available in that spec.
At the very least I'd replace the 6.8 and 22 since they are most likely to have drifted. The 1/50 caps are very common, and only cost pennies each, so installing higher quality devices shouldn't break the bank. The peace of mind from having a completely updated unit should be motivation enough. The chance of losing RF performance is slim with good quality devices and good techniques (moderate temperatures, good connections, cleaned up repair areas, etc.).
Watthour - thanks for your analysis, I'll get those caps ordered.
In other news, I successfully implemented the heat sink mod to Q25 and Q19, the middle and rear-most transistors. Radio Shack only had 2 heat sinks in stock, so that's all I did. As it happens those two were the ones that showed signs of heat - the front one doesn't look too baked.
Still waiting on the power supply filter caps - they're coming from a vendor in Hong Kong and should be here any day. That raises a question - since all I could find were snap-in caps in the large size, will this be a problem? any special trick to mounting them up in place of the standard axial caps that are there now? also, should I bypass them with smaller caps across the leads? I've seen talk of this procedure, but am unsure why it is a desirable modification.
Shouldn't be a problem as long as the distance between the leads is compatible. A bit of Contact cement on the bottom of the cap will assist in holding the cap to the board, as the originals had 3 leads (one was for stabilization). I gutted my originals and put IIRC 10000uf/63V Nichicon's (can't remember series now, but it was low impedance) inside the old can's. BTW the Originals are RADIAL not Axials.
Larry
Larry
I found your post RE: gutting them, after I posted. Nice thread - thanks! I'm using a pair Panasonic 10000uF 50V Au E Caps, and while the 25mm case diameter is similar to your Nichicon's they are snap-ins, not leaded.
These:http://www.analogmetric.com/goods.php?id=867
The description says 30mm, but they told me they were definitely 25mm.
And yes - I know they are radial.... I mistyped. My problem is that I know what the difference is and what I need, but I frequently swap the terms. :(
BTW - my main board is a revision "H" - a little farther on down the line from your "D". I had to revise your handy list just a tad. :)
Those caps will change the vr1 and vr2 adjustments a bit.
a reasonable adjustment is to find where in vr1's rotation the stereo lamp goes from OFF to ON (NOT from on to off!!!) in the CCW and CW directions and then split the difference.
IF you have a frequency counter, with NO stereo signal (inter station static) just adjust tp23 to (4 x 19 khz) 76khz.
Vr2 is a pilot subcarrier null adjustment, and you need a quiet stereo receptioon or a high pass filter to see the 19khz and above signals and adjust vr2 for their lowest amplitude (on a scope). with an fm generator we can send a "quiet" test tone so only the junk shows up.
DO NOT change caps around the pa3001. There are some that can be changed without compromising the adjustment, but it's tricky.
Should my starting point be a station tuned in good and strong, and then turn the pots? I'm not sure what I should do here. If you have the time, detailed instructions would help out tremendously. If not - no worries. I know you're slammed and have bigger fish to fry.
Do not have any of this - no frequency counter, no scope, no FM generator.....
I did not change any of these - they all appear to be little wafer/disk type capacitors, and I left them alone. I DID change C27, C28, and C34 with no apparent ill effect.
FWIW - this little receiver is just blazing away. I've been listening to a "not too local" FM station all day/night, and with a standard di-pole antenna it is pulling it in good and strong.
I think it's safe to say if you're pulling in a distant FM station and it's signal is strong, leave it be.
Larry
Larry
My thoughts exactly. :) When I'm all done, I may bring it down to the local guy to have it aligned, anyway. He's given me a ton of free advice, and this thing hasn't been touched since I bought it in 1978. Since it is my absolute keeper, I think I'll have it set perfect and toss some business to the last decent repair guy standing in my community. Win-win, and I get another 35 years out of my little buddy.
Also - the snap-in caps I ordered arrived, and the leads are a different spacing than the originals. I don't think they'll fit. Since I ordered the ones you specified in your post a couple days ago, I'll hold off and use those. They should fit the bill. Heck - I may even follow your lead and put the new ones in the old cans.
If you DO stuff the can's, make sure you get out ALL of the Gunk. The new caps are just small enough to fit with no real clearance inside other than length IIRC.
If you've had it this long, that recap just paid for itself in longevity for another 30 years. Definately treat it to a alignment and ensure it's 100%! It'll pay you back in spades. I've had mine for about 4 years now, and it hasn't given me a day of trouble. I've gone over every thing EXCEPT the tuner. Tuners to me are mumbo jumbo things. I don't touch them except to clean the Vari-cap. The 780/790 is definately a keeper. It may outlast my Fisher 400 and Fisher consoles. But they are in a different class....Apples and Oranges.
Very GOOD Sound, Decent Power, Competently laid out, Good Looks, Easy to work on, no real problems, parts available without costing an arm and a leg, or your 1st born grandchild.
Wish I had TWO!!
Larry
Help.
Disaster has struck. I was putting in the last of the tuner capacitors, and got distracted by the wife and daughter. Instead of putting my work down, I somehow ended up apparently working on a live circuit - either that, or there was a charge stored up somewhere.
I was soldering in C41 on the tuner board, and got a spark and a small jolt on the fingertips holding the solder. It happened fast - I'm assuming I shorted the two cap leads together via the soldering iron.
FM is now kaput - no stereo lock, but the FM signal meter seems to work. If I turn up the volume all the way, I can faintly hear the FM station - but only on the right channel. AM seems to work, and other inputs (CD, TT, etc) are fine.
I tried putting the original cap back in, but that did not help. I replaced it again with another new one - no dice.
C41 is directly connected to pin 9 of PA1001 chip on one side, and VR2 on the other. I'm freaked out about this. If I've damaged that chip, I doubt there are any available for replacements.
What have I done? What can I check, in the hopes that it is something I can recover from?
I've carefully measured the voltages on each pin of PA1001:
Pin 1 12.52
Pin 2 4.48
Pin 3 6.73
Pin 4 11.75
Pin 5 5.99
Pin 6 6.03
Pin 7 0
Pin 8 .27
Pin 9 .47
Pin 10 3.78
pin 11 3.72
pin 12 3.78
Pin 13 3.84
Pin 14 3.85
Pin 15 4.97
Pin 16 1.07
Most of these are pretty far off the values displayed on the schematic, but pin 8 is way off. It should be 5.7v :(
Sounds like you had some sort of residual charge on the board. It may have fried the chip.
Hopefully MTF gets on here sometime soon. He's been super swamped lately and will be for a while.
In the meantime, Check with Yesterday's Audio for a Tuner board. He may have one fairly cheap. IIRC the "PA" chips are proprietary and the only way to fix is with a transplant.
Larry
Larry
Larry,
Thanks for answering up - I'm really beside myself over this one. This particular unit is my baby - it is the reason I bought and fixed two others, so that I would have the knowledge and skill to not screw this one up. That didn't pan out. :(
I swear the receiver was turned off but it was plugged into the DBT, so I don't know if that keeps things warm or not.
Anyway, I've located, though private channels, a pair of "for parts only" tuner boards. I'm thinking of buying both of them just to have the chips.
Now, here's a question - how can I SAFELY de-solder the 16 pin chip? Is there a certain method or special tool to keep from heat damaging it, or should I just use the iron and sucker/wick to get it out of there? Once I do, I plan on going with a 16 pin socket - good idea, or no?
Never done a chip, but I imagine it would need some sort of heat sink on the pins (alligator clip or something). Solder wick, and a iron that has a small tip. Alternate ends after each pin undone. 1-9-2-10-3-11-4-etc..... I like the socket idea.
Go to a Computer shop, and see if there is a gamer there that builds his own and modifies them and see if he can remove the old chip and the spare, and install the socket and the new chip.
Always unplug before working on any unit. Then short the Filter caps. Check for voltage in the area of work. Good insurance. All the DBT does is show you a current (amps) load visually when on. It won't facilitate power to the unit.
Larry
Yeah - lesson learned. I was able to score a pair of tuner boards cheap, so they're on the way.
I know MTF is very busy, so I don't want to be a time-sink for him - especially since this wound is self-inflicted.
I think I may be wise to quit before I smoke something else. I called the local stereo repair guy (who I know and trust) and explained the situation to him. He says that as long as I have the spares in-hand when I come in he can fix me up.
I think I'm going to toss some money his way, have the tuner repaired and aligned by a professional, and walk away before I do any more damage.
Good Call. Glad you got extra parts in hand (or soon to be.). Sometimes I think we tend to get in over our heads without realizing it, especially with audio gear. As long as it comes back running like a champ, no real harm done. But it will be a learning experience.
Got mine running the Main system in the living room right now. Either I need a smaller room or more oooomph in it. Guess it's time to fire up the 1010 again and relegate the 790 to the bedroom.
Larry
I know enough about this stuff to be dangerous, and this time it bit me on the ass. If it were anything else I'd plow on and see if I could get it done on my own, but the combination of a suspect IC and a tuner board is more than I care to handle.
Since the capacitor I was fooling with at the time of the spark was connected on one lead to the PA1001-A chip and a variable resistor on the other, I can't see how it could be anything else. Just for fun, I replaced all the surrounding new caps that I had just installed, but the symptom is still the same. Up until that last one I had been testing after each one, so it was good to go up until the spark.
Just to follow up and close this one out......
Just got a call from the local guy. I did indeed blow up the PA1001-A chip, and he was able to successfully use my spare to get the receiver going again. He did a tuner alignment while he was at it, and he said it wasn't that far off.
As you say, no harm done. Except to my wallet. Ouch. :)
I have one spare tuner assembly intact, and another missing only the PA1001-A chip. Anyone need a spare SX-780 tuner, complete with the unobtainable, highly prized, and rare HA1197 and PA3001-A chips? :D
Glad you didn't give up on the unit. Looking at it philosophically, you DID state that you intended to have it aligned once the work was complete to both get your old buddy running like new and to keep the local repair shop busy. I'd say you've accomplished your mission.
Looking at it superstitiously, you DID work on in on Friday the 13th, and that just happens to be the day when "IT" happened.
Both ways, you're moved past that and are rolling in ♫♪♫ again. 780s are nice units. I have two and another on the way as a project. I think they are under-rated in power, and sound cleaner/fuller than many of the X50 models, and certainly more full-spectrum than the older 7X7 models (very bass mushy).
Friday the 13th?!?!? Damn.... what was I thinking? :sigh: :D
Steve over at Stereo Doctor in Dublin CA is a good guy, always has time to chat about music and stereo gear, and gives advice freely. I don't mind in the least throwing some $$ his way.
Besides - in on Friday mid-morning, out on Monday mid-morning. Can't bitch about that!
