Mr. Noble, that is. A.K.A., the "Six Million Dollar Switch" to small SX-x50 owners.
I picked up a fairly clean SX-750 and the switch had been jumpered previously. I didn't want to operate it by plugging in or via a power strip, so there was little choice but to replace or repair the switch. If you have ever searched for one, you might understand the reason to do what follows.
The switch can be removed from the rear of the speaker selector rotary decks. Once the bottom is off the unit and face plate removed, the switch can be removed and exposed without unwiring. Desolder the leads and MOV-X/Y capacitor, then remove the power switch from the speaker selector stack. The rivets holding the switch body to its metal mount are aluminum, and can be re-formed and driven from the plate to allow opening the switch.
[/IMG]
With the switch open the plain toggle mechanism can be observed and the damage can become apparent. In my case, the stationary contact (a simple copper post) was heavily pitted and the connection between the copper post and its solder lug had become loose, allowing intermittent contact. The stationary copper contact can be rotated and re-staked to the solder lug, then soldered in place securely. The movable contact on the toggle arm can be cleaned acceptably, and the switch can then be reassembled.
In my case, that solved the problem completely. I may eventually install a relay to take the main power load and have the switch pilot the relay only, but I should have just bough myself a few more years on the switch contacts.
It appears that a variation of the Noble rotary switch is still available, but appears to be attached to a potentiometer:
http://www.analogmetric.com/images/200906/1246134414828393003.jpg
Looks like it can be found --->HERE<---
In the future I may have to investigate the viability of using one of thee potentiometers as a donor for the Pioneer power switch application. In the interim, if you are reasonably skilled you can probably do as I did and repair what you have before it is beyond recovery.
EDIT: Update photo links
[/IMG]
