jeremyjustic
Analog
check out this td150, the headshell looks like the wrong thorens headshell, tht arm should have the silver one correct? this is a big no no on these arms right?
http://seattle.craigslist.org/see/ele/2532162128.html
This is an original Thorens TD-150 table from the late 1960s, fully restored to better than original condition. Anyone familiar with Thorens turntables knows what they're getting in terms of build quality: extremely durable stuff, made in Switzerland. The platter is a big solid heavy piece of metal. It needed some work when I got it, so I took it apart and cleaned all the components. Took it to the needle shop on 65th... I think it's called J & S? ... the old guy that owns the place knows everything there is to know about turntables and how to fix them up. He installed a new belt, brand new diamond stylus (hasn't been used!), ensured pitch perfect timing with a strobe, oiled the parts, etc. I then had a custom headshell made in "translucent bronze" by a master worker who works with acrylic, which includes thumbscrews in the back that allow you to set the tension on the lid, should you wish to have it "hang" at a particular angle when it is open (in the pictures, they are loose, giving enough slack that the lid can basically rotate as far back as it wants). You can see the translucent nature of the lid from the photos; the last one in particular you can both see the platter through the lid as well as seeing the reflection of my TV, map of the San Juan Islands, etc. reflected off the top. More pictures (or more detailed images) available upon request.
The table is now in absolutely beautiful shape. Requires a phono preamp to work with most modern stereos, but I will include mine if you don't have one already.
