Yes, it is a Harman Kardon 430.
Lots of grinding and filing and drilling.
Also note the new IEC jack, it is cryo-treated silver, fuse holders are silver too
Doubled the cost but for a small keeper receiver like the HKs this is nothing in the scheme of things and the benefit you will get while you enjoy that unit.
Need to be used by a competent, knowledgeable person now to avoid improper connections of the speakers. If those jacks allow use of dual banana plugs that is a big plus but also with the connections spaced so that errors are possible...
Not sure of spacing, I just spaced them as far apart as possible for the given space so I'd have to do less filing.
Even if using bare wire now it is less dangerous than the push terminals before which were prone to bare wires wandering about.
I'm using Solen binding posts which were only $15 for a set of 4. Very high quality and very long threads, so they are good for speakers as well.
The RCAs are just a cheap $3 pair from partsconnexion.
Looking good but what is your reason for doing the RCA connections? They are already convenient RCA and there will be no performance gain. Were they damaged?
I disagree that there will be no performance gain, if there wasn't I wouldn't do it.
The reason is that by this time, normal nickel(?) plated connectors will have tarnished significantly, and they made poor connections.
Also, the plastic and metal that is supposed to grab the inner pin has worn away over time. You can observe this by having a test RCA plug with no ground shell, old connectors will be very loose. Not good.
