KR-10000: no bias reading in one channel, but it plays fine
Raccoon1400
When this unit came to me, the TO-3 outputs had been replaced with TO-3P. I swapped them out for Onsemi TO-3's. I set the bias in one channel to 45mV, but I don't get a reading in the other channel unless I am listening to it, and then it is in the 10-30mV range.
Maybe this is a result of collateral damage that was not repaired when the original outputs blew? Where should I start looking?
The last person in here made a mess of the thing. They rectified the voltage for the lamps, giving it 20VDC instead of 8VAC, blowing all the bulbs, to name one example.
You are checking the voltage between the emitters of the output transistors?
What are the standing emitter voltages for each output transistor (referenced to chassis ground)?
Yes, the voltage between the emitters.
In the good channel, the emitter to ground voltage of the NPN output is 40mV. It reads 0 for all other outputs.
No...bias current is measured (on a common-collector-type output) NPN emitter to PNP emitter (this is measuring across the emitter resistors). NO reference to ground, since any offset will skew the reading.
This is what I did originally, following the instructions in the service manual. I successfully set the bias in one channel, got no reading in the other.
