sKiZo
Hates received: 92644 43.20°N 85.50°W
There's various other restoration threads on AK for this receiver, but my goal here is to do a bit more background for clarification of some of the issues I had ... issues with. Not much in the way of "new", but mostly an assortment of odds and ends I dug up and benefited from on the project.
Which by the way, is moving along nicely once again after a year or two off ...
PS ... the real work starts around post #13 ...
OK ... I've got mods poking and prodding me to start my own thread instead of littering the board with my musings. I hated the poking ... but I didn't mind the prodding. Anyway, here goes with more or less a compilation of where I'm at.
THE VICTIM
All in all, real decent machine as is. Cosmetically a 9+, all the dial lights work, all functions and switches good, clean power all channels and modes. It does have the occasional cutouts when switching modes that would seem to suggest the usual pass thru problems when it comes to these things. I also have some noise - more of a heterodyne thing like an out of spec cap run amuk in one channel that comes and goes. Me being a glutton for punishment (yes ... I pick at scabs too) I've been working my way up to diving in. I've got a spare QRX6001 I'm using in the meantime, so I won't be without music. I also practiced on a full recap on a QR4500 that went well, so I got my feet wet there on all things Sansui.
So far, prep work only. Got my caps sorted - first time I've ever had to go with the old tackle box trick, but then this is the first time I've had that many parts to keep track of. I went with the CDE 12000uf50v replacements for the primary power, then Elna Silmic II, Nichichon KZ where available, then KW. In any case, all audio grade. Also plan to do the fusistors as recommended. Thanx and a tip of the hat to XFORMER for the parts list. I was able to do it all in one order from Mouser with a few voltage substitutions.
That pic was a lot more work than it looks. I also rebuilt my bench and added an "L" so I'd have room to work on the beast. Less room to throw things too - which is probably a good thing.
Also ordered up a Weller analog soldering station and ... tada ... (cue the angels singing) ...
Got the service manuals, ghosted the boards for a while now, bookmarked a bunch of threads, and I think I'm ready to go. Wait ... one other thing. BALLS!
Lemme see ... a ball of twine to keep boards out of the way, a ball of hookup wire for lights ...
THE VICTIM
