In The Groove rolling record cleaner
luvvinvinyl
My best pal, Molly
A past thread about this item drew the attention of its inventor, Dr. Stanley Taub.
The original complaint was that the roller shed some of its sticky coating, which required solvents to remove. Dr. Taub wrote me, explaining that his roller now has a new improved formula, designed to eliminate this very problem, and would I like one, to test. As well, he sent a second, for the OP, who declined the good Doctor's generous offer.
Well, I tried the roller on a fairly nasty example in my last batch of thrift shop used records, instead of sending it straight to my VPI 16.5. Following the package instructions, I rolled it over the surface of the 'sacrificial' duplicate lp. This lp had dust, some foxing, and fingerprints visible on the surface. All the visible dust and most of the foxing came off. Fingerprints were reduced in prominence, appearing as 'faded', but still somewhat present, in spite of repeated applications of the In The Groove. There was NO shedding of the roller coating. I took this record downstairs, to my second table, to hear the results. There seemed to be rather a lot of surface noise still present in the grooves. I tried four different spots on the side, but was unable to consider the album listenable.
I took the lp back upstairs, and ran it through my VPI. Back downstairs, and a quick spin showed the album to be in excellent shape, and eminently listenable, after a wet scrubbing and vacuum dry. The previous noise is not attributable to record wear, just dirt in the grooves.
I would have been greatly surprised if this very dirty record had been rendered playable without a 'wash & vac'. The In The Groove roller did a more than adequate job of removing dust and a stray cat hair from lps that had previously been washed. I usually just use a carbon-fibre brush for that, because that's what I have long used. Still, the In The Groove roller was adequate for light cleaning, or maintenance cleaning, before play.
The packaging did state that the In The Groove roller was also good for cleaning lcd monitor screens. I tried it on mine, again, following instructions.
AHA! This roller did a brilliant job of cleaning my monitor screen. (My cat likes to chase the cursor.) I am very happy with the results of this use of the In The Groove roller, as a screen cleaner.
Thanks, Dr. Taub.
Thanks Ernie! I saw one of those in the new Music Direct catalog and thought about giving one a try for quick cleaning between washes on my Nitty Gritty RCM.
