Brian - Merry Christmas to you and yours!
It would help narrow down things if we knew where you're at. There might be someone reputable right in your neighborhood.
R11 is a series resistor in the 56v leg that goes to pin 14 then to pin 4 of amp board. I will try to post a pic of the PS schematic. It worked for Matt when he did the work, then shipped to Brian which is where the symptoms started. It was battered by FedEx on its way to him so it is very possible something else was damaged.
It is so great to see you posting Mark. I hope you are doing better everyday. As to the other boards I will pass it on to Brian.
HVHiFI said:Thank you Matt, I started looking at the amp board schematic and saw those. Any output trans in needs of swapping during the rebuild? I honestly never even looked back there.
