H/K t60 overhang help needed
Gravelyguy
Hi Guys,
I downloaded the gauge from VE and discovered that I can't extend my m91ed cart far enough to touch the flap let alone get the tip of the stylus to it. If anyone has experience setting the overhang on this and can help me out I would greatly appreciate it. The cart is about a cm or so from where it should be.
Thanks,
Dave
Oh, nevermind, I see there's a flap on the factory gauge. Did you find that for download? Maybe the scale was off... Try the "stupid" 2-point protractors - first two on the tools page. Stevenson or Baerwald will work (probably not both)... looks like maybe Baerwald.
I will pull out my Baerwald and try, but still not sure what the overhang should be.
Dave
If you can Baerwald the cartridge, the heck with the overhang. That is what the Baerwald eliminates, the need to care about overhang. It puts the stylus where it should be for proper playback.
Dave - I have the original tracking angle gauge, if you like I could mail it to you. I didnt get my cartridge to touch the exact location of the arrow on the flap either - just a hair off. However, it is parallel at both points @66.04 120.90. Robert
If you align correctly to Baerwald, or Stevenson, or anything else, the overhang is correct for that alignment. Setting a particular overhang while square in the headshell is a shortcut to the alignment intended by the manufacturer.
Overhang is 18mm - centerline of spindle to stylus tip ... but by all means use an alignment protractor.
Are you using an original headshell? If not you might not have enough adjustment range ... and also remember the angle is unique so without the original you'll have to twist the cartridge in the headshell.
Thanks Guys for all your help. In my noob way I forgot to check the scale and Dumptruck was correct it wasn't printed to scale. I wil do a redo tonight.
I had it set up with my Baerwald protractor, but wanted to see what would happen if it was set up like the owners manual suggested.
1gr8e320a, thanks for the offer. I think I will be ok. Did you get your table back?
Thanks again,
Dave
According to the specs at VE, the effective length is 226 mm, overhang is 18 mm and the offset angle is 25.5 degrees. But if you use their calculator for cartridge alignment and assume a pivot-to-spindle distance of 208 mm (226 mm - 18 mm ), Baerwald would give you overhang of 18.3 mm and offset angle of 24.3 degrees. So you really have to simply choose which one you're going to align to...manufacturer specs or a protractor.
If you can't get the cartridge forward enough in the headshell to align to Baerwald then print a Stevenson protractor and use that. Stevenson uses different null points that allow the cartridge to set further back.
According to the specs at VE, the effective length is 226 mm, overhang is 18 mm and the offset angle is 25.5 degrees. But if you use their calculator for cartridge alignment and assume a pivot-to-spindle distance of 208 mm (226 mm - 128 mm ), Baerwald would give you overhang of 18.3 mm and offset angle of 24.3 degrees. So you really have to simply choose which one you're going to align to...manufacturer specs or a protractor.
If those numbers are correct, the manufacturer's alignment doesn't look too hot:
comparator_plot.php
I didn't futz with the overhang on my T60, just set the alignment by the protractor. Now I might go back and use a Baerwald alignment...
Unsettling isn't it? 1.2° difference doubles the tracking distortion (that tiny overhang difference ain't doing anything).
Dave, I'm picturing you hunched over your new HK TT like a mad scientist trying to get it "just right". My little brother has become an audio madman!!!
Fun isn't it? I can't wait to audition your new toy. Take care, John
I got her set up last night. And it sounded great. I put it through a some paces, but I still have some questions. In looking at the H/K protractor, the null points are 66.04 and 120.9 mm. Wouldn't this make it a Baewald protractor? If it is then something is off when compared to dumptrucks graph.
Regardless, it sounds great. It has a little deeper soundstage than the SL 1700 and I was able to hear more subtle things particularly backing percussion instruments.
Thanks for all your help guys!
Dave
Been playing mine non-stop since I got her home. Let me know what you think of yours after a weekend of playing time. Thoughts on the quartz? personally I prefer it off.
